Did I screw up my exhaust?
I recently had both of my cats removed due to a plugged drivers side. I installed 02 sims. prior to their removal. The sound is a little raspier than before, which is kinda cool. I want to know if adding sims. and removing the cats is gonna have an effect on the engine or anything else for that matter. Any and all input would be appreciated. Thx.
My car has no cats and 02 sims, just like what you did. The sound is nice and raspy, but it tends to spit and sputter too much due to ( i think ) the lack of backpressure. I'm not sure if 02 simms will give varying readings back to the computer, since a real 02 sensor would be changing, making the engine run different based on that feedback.
I also hear that taking out cats will make you lose some low end torque.. but i'm not sure...
I'm probably going to put on some high flow units from Random Technology soon, mainly due to the annoying popppaopopopppbwwaaaaaaa when i downshift...
Ive been running rear O2 sims since I put my longtubes in. Ive tried running with and without cats since FLP has that capability. No problems with the O2 sims...just make sure your pre-cat O2 sensors are functioning OK. I can relate to the loud sonic whoas of running no cats...in fact, it made me put the cats back in. The car was simply way too obnoxious for the street. The cats take away alot of the raspiness and popping.
Running gutted cats and rear O2 sims will in NO way harm the engine, or anything else. The only thing it might do is cause the knock sensor to pick up false knock if it is really loud.
The PCM doesn't use the rear O2's to adjust anything on the engine. They just let the PCM know if the cats are working. If they aren't, then they will throw a SES light.
Dan
Dan
Originally posted by 2cub49
My car throws the P0400 EGR Code even though I have the EGR Fitting on my longtubes.
What's this simulator you're talking about.
Originally posted by Rashiki
The popppaopopopppbwwaaaaaaa when i downshift...
Great if you can email me a schematic I would greatly appreciate it.
The funny thing is if I leave my IAT module in which tells the pcm its always 37F it doesn't throw the PO 400 egr code.
But if I take it out it does.
Since I'm gonna be running my supercharger soon i don't think I'll be using the IAT module any more.
I'm getting my car inspected in may before they start emissions testing in june here in Buffalo,so I'll have a year to sort out a few other minor codes.
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
