Did I block the EGR the right way?
Old Apr 7, 2003 | 09:20 PM
SplitFire's Avatar
Question Did I block the EGR the right way?
Not sure if I did it right or not when I finished my headers up. The only thing I blocked off was where the pipe from the exhaust manifold went into the back of the intake. I just had the hole welded shut. Is there anything else that has to be done?
Old Apr 7, 2003 | 10:00 PM
DubbyZ28Camaro's Avatar
Make sure you block off the big hole on the back of the intake otherwise you will have a serious vacuum leak going on there!!! I bought some blockoff plates from someone on the board here for like 20 bucks or so, but I can't remember who.
Old Apr 7, 2003 | 10:02 PM
SplitFire's Avatar
Yeah, that's the only one thing I did block off. Was there anything else that needed blocked though?
Old Apr 7, 2003 | 10:03 PM
If you left the EGR valve on and removed the vacuum line to it, you are ok.
Old Apr 7, 2003 | 10:08 PM
On one end of the tubing is the intake manifold, which you said you have blocked off, on the other end of the tubing is a port off of the exhaust manifolds, which you also need to have blocked off (unless your headers came without the EGR fitting then you don't have to worry about blocking off the port on the exhaust manifold!!)
Hope this helps!!!
Old Apr 7, 2003 | 10:19 PM
Wildwill532's Avatar
should just block the pipe to the exhaust manifold and that is all you need to do, to block the egr
Old Apr 7, 2003 | 10:21 PM
SplitFire's Avatar
Yeah, my headers aren't emissions legal so I don't have anything on the headers themselves to worry about plugging up. In Shoebox's picture where it says EGR pipe to exhaust manifold, that is the hole that I sealed up. I didn't touch anything else but that.
http://csce.uark.edu/~jgbertr/rb/intake_rear.jpg
Old Apr 7, 2003 | 10:24 PM
anaik's Avatar
You're cool
Old Apr 7, 2003 | 10:27 PM
Yeah, you're fine then!!
Old Apr 7, 2003 | 10:29 PM
SplitFire's Avatar
Good deal. I just wanted to make sure because it is taking the car a just a little longer to start up than it did the first time i turned it over after the install. But I read in another post that that since right now it's just open headers, that the o2's could be reading wrong and causing the car to run rich. I'll find out tomorrow though since it will all be getting hooked up. Thanks for all the replies.
RUENUF
Mar 13, 2016 03:37 PM
marlar98
Oct 21, 2015 02:02 PM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
