Did auto lt1s have vibeshaft problems..
Old May 10, 2004 | 08:26 AM
80TA's Avatar
I have taken my 96 up to pretty high speeds around 140mph and didn't notice any extreme vibation like I did on my old 96 and 97 m6 cars.Is the manual lt1 the only ones that need the 1le or ls1 shaft.Do the auto cars not have this problem???
Would an 1le shaft still pick up 5 or 10 hp though from being lighter than the stock shaft..
Old May 10, 2004 | 12:12 PM
Patman's Avatar
It is rare, but auto LT1s can get the vibeshaft problem too. Mine has it, and I know of one other LT1 owner in my f-body club who had it too. In both cases, the cars have 3.23 rear ends, which magnifies any imbalance in the shaft compared to 2.73s.
With me, I notice it beginning at about 80mph, although it's not a major amount there. It's noticeable enough that I would not be able to sustain 100mph highway speeds for very long though, just short bursts.
Old May 10, 2004 | 12:34 PM
RCF925's Avatar
I had the same vibration in the DS in my 94 M6. I turned it 180* in the U-Joint and the vibration is almost gone.
Old May 10, 2004 | 12:35 PM
neil350's Avatar
Mine has it, but I really dont notice it.
Old May 10, 2004 | 12:53 PM
BUBBA's Avatar
There is an old Bulletin that covers up though 96 regarding possible DS vibrations. The fix was replaceing with Le shaft. Most here have gone with the Ls1 aluminum shaft. or the Le shaft.
Don't know why the bulletin didn't cover the 97s, but apparently the problem was supposed to have been fixed.
Many had their DS replaced under warranty, but, of course that is not the case anymore.
Old May 11, 2004 | 10:45 AM
HK45's Avatar
My 95 had a bad shaft. It started at about 100+ mph at first. A few trips to the track and some hard driving, and it got worse. Eventually it was humming at 80 mph. About 2K miles later, it killed my tailshaft seal on the tranny. (puddles of fluid in the driveway) . At that point I changed the seal and the whole driveshaft to a 1le. I have a tiny leak on the pinion seal now but its not bad enough to worry about. The rearend is coming out soon anyway for 3.73's.
Old May 11, 2004 | 10:56 AM
wes95_z28's Avatar
My has a bad vibration at 100+ and i have the 2.73 was thinkin about 3.73s but i wanna fix this first.I flipped it 180* and it only got worse im gettin an ls1 shaft
Old May 12, 2004 | 12:17 AM
roadtrip120's Avatar
My DS was vibrating at 86mph-135mph, then after that it went a way. A real uncomfotable fealing i might add. I bought a Aluminum one of ebay for $75. No problem now all the way to 155mph
Old May 12, 2004 | 12:23 AM
Somnambulist's Avatar
Re: Did auto lt1s have vibeshaft problems..
I dont think so man...
Old May 12, 2004 | 12:30 AM
Pasky's Avatar
Driveshaft does not give you horsepower, its still behind the same engine . It gets the rpm's up quicker, thats it.
Old May 12, 2004 | 12:45 AM
Knowklew's Avatar
A lighter driveshaft does not give more hp but it does free up lost hp by having less rotating mass.
Old May 12, 2004 | 12:59 AM
so does a pulley...5-10 hp? I think not...
SinisterRacing1
Mar 7, 2015 03:44 PM
jb4xx
Feb 2, 2015 10:00 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmsmith
Jan 5, 2015 07:04 AM
Injuneer
Dec 15, 2014 09:36 AM
