diagnostic port wiring
Old Jan 8, 2006 | 07:25 PM
sw89lt1's Avatar
when i got the harness with my motor it did not have a diagnostic port. i've got the port but i need to know what wires from the computer go to what pin on the port.
thanks for any help.
Old Jan 8, 2006 | 11:08 PM
Re: diagnostic port wiring
Did you get the OBD-I 12-pin ALDL connector, or the OBD-II 16-pin connector? That will determine how you wire it up. The 95 (you indicate its a 95 LT1) has a mismatched system, using an OBD-II connector, with an OBD-I PCM. Shoebox has all the 95 wiring diagrams on his website:
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
If you got a 12-pin connector, you will need to look on his website for the correct pinout.
Noenav
Mar 1, 2019 07:38 AM
squarehead
Jan 15, 2015 07:02 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Jul 4, 2005 05:00 PM
