Desensitizing Knock Sensor?
Old May 2, 2003 | 06:43 PM
C Man's Avatar
It seems like I'm getting some odd knock that cannot be attributed to bad gas (used race gas and it's still knocking).
There are no exhaust leaks and I have the LT4 knock module. The car seems to do it intermittently... usually at WOT but often on regular acceleration as well.
I did have the car programmed last year by ARE when I dyno tuned the car with wide band A/F sensor. At that point I did not desensitize the knock sensor but I heard that this may be possible.
The question I have is: When changing the sensitivity of the knock sensor... is it possible just to decrease the sensitivity or does it just turn it off?
I've been using 92-94 octane in the car... other than possibly getting a bad batch of gas, would completely turning off the knock sensor put me at risk of severely damaging the car? If so... I may just do the resistor mod instead, and figure out a way of turning it on/off when racing. (ie. creating a switch that other runs through the resistor or not)
Thanks in advance guys.
Old May 2, 2003 | 06:56 PM
Rodrigues's Avatar
You can either get a lt4 knock sensor or use a resistor... Turning off the knock sensor can be risky.
Old May 2, 2003 | 07:09 PM
94-3.4's Avatar
His post said he has the lt4 km. I too am using the lt4 km and still getting a ton of knock retard from my rockers. Can you desensistize the lt4 even more of is it pointless?
Old May 2, 2003 | 08:00 PM
Timberwolf's Avatar
what value resistor do you use to bypass the ks?
Old May 2, 2003 | 09:09 PM
C Man's Avatar
If you do a search... this has already been discussed. I have it on my favourites at home...I'll post a link tomorrow for your reference.
To my point above, I was hoping someone would know whether you could desensitize the knock sensor with programming without actually disabling it completely. Anyone know?
Old May 2, 2003 | 09:12 PM
Timberwolf's Avatar
actually rodrigues sent me a link with the info and a built in calculator, so I'm all set
Old May 2, 2003 | 09:26 PM
Timberwolf's Avatar
As far as tuning it down some, I suppose you could set max retard values in the tables, as well as adjusting how fast it lets the advance come back in... I'd set it for a max of maybe 2 degrees retard, and set it so that advance comes back as fast as possible...
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
