descreened my stock maf?
Old Nov 16, 2003 | 10:19 AM
zoso1959's Avatar
Question descreened my stock maf?
I would like to here your thoughts on descreening a stock maf? what are the pro's & cons . and should iI do it atfer I had my car performance tuned? Is it as simple as cutting out the srceen?
you can see what I've done to my car in my sig.
thanks
tony
Old Nov 16, 2003 | 10:25 AM
ibanez6rg's Avatar
It's not worth it.
Old Nov 16, 2003 | 10:32 AM
TheZ's Avatar
go an do it
Old Nov 16, 2003 | 10:40 AM
zoso1959's Avatar
why or why not
Hi guys
I was looking for more answers on the tech side as too what would happen, not just simple yes or no answers.
can you explain?
thanks
Old Nov 16, 2003 | 10:45 AM
The screen is there to insure the air flow is uniformly distributed over the open area of the sensor, to provide for calibration over a wide range of flows, from idle through WOT.
In the early models, you can remove the screen by simply prying a thin spring ring out from behind it. That way, if you remove it, and don't like the results, you can put it back in. Not sure if the screen can be removed this way in a 97.
I've seen removal cause a loss of fuel economy or up to 2.5MPG, or to cause a slightly rough idle. Other people see nothing. Some people see near-miraculous SOTP increases in "throttle response". I seriously doubt the screen offers that much resistance to flow in a moderately modified engine.
Old Nov 16, 2003 | 10:50 AM
NYCz28's Avatar
Wow, this may be why my MPG is down to like 1mpg, im deff gonna go a rescreen it. Thanks for the info!
Old Nov 16, 2003 | 10:53 AM
1msfyter's Avatar
Ditto . I didnt notice any difference either.
Old Nov 16, 2003 | 11:25 AM
96z's Avatar
96z
Leave the screen in.
Old Nov 16, 2003 | 11:41 AM
zoso1959's Avatar
thanks fred, I'll leave it alone.
i've seen that alot of people value your
opinion & knowledge...........
tony
Old Nov 16, 2003 | 12:54 PM
smokerZ28's Avatar
I descreened mine and no ill effects have come from it, my MPG isn't what it should be, but it was like that before the MAF descreening. I didn't notice a SOTP gain, but throttle response was a little quicker and my engine got a little louder at WOT. Mine didn't set any codes or anything though.
Old Nov 16, 2003 | 02:05 PM
Z95m6's Avatar
i descreened and ported my maf when i first got my car and wanted to do some mods to it. After i got a scanmaster i saw it messed my BLM's all up so i now have a stock, screened MAF back in my car.
Old Nov 16, 2003 | 02:08 PM
AxeGrinder30thZ's Avatar
Leave it in. I hate hearing about how people "gained a HUGE SOTP feeling from it" or "it had to add at least 10 hp!". That's BS.
Old Nov 16, 2003 | 03:10 PM
bunker's Avatar
No kidding, at most you can try descreening it & you might gain a bit of HP at WOT & like 6k rpm, but for everyday driving you'll loose mid range power/fuel economy, & with a big cam I notice the cam surge is minimal with a screen.
Leave it.
BTW, I think 96+ is when the screeen is epoxied in, before that it was just a c-clip.
Old Nov 16, 2003 | 04:30 PM
DiabloZ's Avatar
How many times has this topic been debated?? Over and over with hundreds of opinions..
Old Nov 16, 2003 | 05:52 PM
speed_demon24's Avatar
Run 1 with stock screened MAF 275.8rwhp
run 2 descrened 278.9rwhp
run 3 descreened, 277.1 RWHP
Right now I'm makin 302.9rwhp and the a/f is dead on with my tuning, so I see no side effects of descrening it, I gained 3rwhp by descrening it.
