Deprogram computer LT1
Old Jun 28, 2007 | 06:32 PM
Danny McAdams's Avatar
I am trying to take the program out of the computer in 94Z so I can put a program in 95Formula. I followed the steps in Hypertech instruction book, but the programer says it can't comminicate with the computer. There is no eng. in car nor a battery, do I need a battery to wake computer up so programer can communicate with it. I took the computer out and unpluged and pluged back in to be sure of connections. What the heck do I need to do, HELP! somebody. Danny Mc
Old Jun 28, 2007 | 06:45 PM
LiENUS's Avatar
The car needs the battery on and the key turned to on most likely (though you shouldnt need an engine)
Old Jun 28, 2007 | 09:30 PM
stereomandan's Avatar
Yes, the key should be to the run position. Or else, make sure there is power to the PCM.
Dan
Old Jun 28, 2007 | 10:34 PM
So far the concensus of opinion is. "I gotta have a battery in the car". If that don't work I will put the Z computer in Formula and try to erase there, then put Formula computer back in and try to program. Danny Mc
Old Jun 28, 2007 | 11:38 PM
hotrod18_69's Avatar
Yeah you need the batt in the car and make sure you have your PCM ground hooked up somewhere.. Its suppose to hook the the engine..
Old Jun 29, 2007 | 12:44 PM
I hooked a 6amp battery charger to pos and ground, Viper alarm sys. went off, I waited till it quit then hit buttom 10x that is supposed to get it back in sync. Computer still won't communicate /programer. Can I put computer in 95 Formula, not to start it just be able to get program out, I think the Viper still has me blocked, don't know just a guess. I really don't know where the computer ground is or what wire. Danny Mc
Old Jun 29, 2007 | 05:08 PM
1SlowFormula's Avatar
You should be able to put it into your formula and then pull the program from it...
Old Jun 29, 2007 | 08:33 PM
Yes putting it in your formula should work as well..
Old Jun 30, 2007 | 12:03 PM
I swapped the computers from 94Z to 95 Formula, guess what the ports under dash are different- back to square one. I don't think I can use the M6 computer on Auto car. Did find computer is good, started car but did not attempt to drive. I got to find why I get no communication on Z car. Any one can tell me where the computer ground wire is, could be whats wrong, who knows!! I am following the book. Hypertech was no help. FLASH!! A guy just called me and said computer needs at least 8amps so 6amp battery charger won't work, now going to get battery and try again. Danny Mc
Old Jun 30, 2007 | 12:12 PM
LiENUS's Avatar
http://shbox.com/1/xraycable.jpg
Old Jun 30, 2007 | 03:08 PM
LieNUS: Will that give me full access for the hypertech programmer to work. Danny Mc
SinisterRacing1
Mar 7, 2015 03:44 PM
InfernalVortex
Jan 17, 2015 09:35 AM
4586
Dec 6, 2014 05:20 PM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
