Delteq stronger spark.
Old May 15, 2004 | 05:28 PM
96z's Avatar
96z
Delteq has stronger spark?
Im just starting to research the delteq system and it seems to be a better option than get an MSD 6a or 6al in looking for a stronger spark. Being that the coils are much larger and greater in number Im assuming the strength of the spark corresponds. Is this true? Has anyone installed a delteq and gotten rid of missing or hesitation especially in the upper RPM's?
Old May 15, 2004 | 07:21 PM
kmook's Avatar
Advanced Tech Moderator
Yes it is a much stronger spark than stock or a 'improved' setup with a 6al. I had REALLY bad hesitation, but it was my o2s not my opti, so the delteq did not 'cure' any problems for me. But i did it for the improved opti life and stronger spark.
Old May 15, 2004 | 08:56 PM
Robs97Z28's Avatar
Delteq is an awesome set! it is eazy to install and the isn't ANY splicing at all. It is a simple plug in set up. uses factory plugs and wiring harness. It is very clean install.
Old May 15, 2004 | 11:04 PM
96z's Avatar
96z
Excellent sounds like what Im looking for.
Old May 16, 2004 | 08:12 AM
Robs97Z28's Avatar
When you call, Pete most likely will answer the phone. He is very helpful and has a ton of info about the LT's. Good luck. let me know how is works out, Rob
Old May 16, 2004 | 12:46 PM
flyinZ's Avatar
Can anybody give me a little more info on this...I've seen this before, just not a whole lot of "talk" about it...Got a site, price,etc?
Old May 16, 2004 | 01:13 PM
Alex94TAGT's Avatar
FlyinZ -- if you run a search for Delteq or LTCC in the LT1tech and AdvancedTech forums, you'll find all the info you could possibly want. But, Delteq's website is http://www.delteq.com
Here's a few shots of mine, which has been deemed "ugly" due to my wire routing:
http://hometown.aol.com/alex94tagt/delteq.html
http://hometown.aol.com/alex94tagt/hostedphotos.html
HTH
Old May 16, 2004 | 01:16 PM
Robs97Z28's Avatar
here ya go bud; http://www.delteq.com/opti_pricing.htm
just cruise throuth here and what you are looking for. If you have any other question I will do my best to answer then. I have had this on my ride for a few months now wnd love it. Just as a note. GM is using type of ignition the 3.8 V6 camaros. I am at a total loss why they put them on the v8s. just my 2cents..
Formula Steve
Sep 19, 2023 08:31 AM
tommalcolm
Sep 11, 2015 03:39 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
karpetcm
Aug 14, 2015 03:02 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
