Delteq installed but car stalls right after starting
Old Sep 29, 2005 | 10:50 AM
tiafn2's Avatar
Hey guys, I'm new to the board here and I'm hoping I can get some help for a problem I'm having. I just installed the Delteq system on my 1994 Z28. Installation went smoothly and I performed all the suggested diagnostics checks throughout the installation to make sure everything was working correctly. When I start the car it fires right up and sounds better than it has in years but then quickly stalls out no matter if I give it gas or not. I've looked back at most of the threads about the Delteq and couldn't find anyone with the exact same problem. Has anyone else had this problem with the Delteq system or know what might be causing it? Thanks in advance for the help.
Old Sep 29, 2005 | 11:16 AM
Tom Piper's Avatar
Re: Delteq installed but car stalls right after starting
I think Delteq recommends pulling the injector or fuel pump fuses to check the spark at the coils.
Did you re-install the fuses?
Tom Piper
Old Sep 29, 2005 | 02:04 PM
tiafn2's Avatar
Yeah, the fuses are in. I've gone over the whole system a couple times to make sure the wiring harness, plug wires, etc. are in correctly. What gets me is that it's getting air/fuel/spark at least initially but something is stopping that.
Noenav
Mar 1, 2019 07:38 AM
Ari G
Dec 11, 2014 03:21 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
