Delphi O2 Sensors (afs-75) Acdelco???
Old Nov 10, 2004 | 08:36 PM
Fbody1's Avatar
Question Delphi O2 Sensors (afs-75) Acdelco???
i found some 02 sensors at getgmparts.com ($28.75 each) that were delphi they said that they are the company that makes the acdelco 02 sensors has anyone ever used or heard of this before? their part# is es10006 any info on this please let me know
Old Nov 11, 2004 | 06:29 AM
Fastbird93's Avatar
Re: Delphi O2 Sensors (afs-75) Acdelco???
While I can't confirm whether or not they are indeed the maker of the Delco O2's, I will attest that Delphi is definitely quality stuff.
Old Nov 12, 2004 | 06:49 PM
Fbody1's Avatar
Cool Re: Delphi O2 Sensors (afs-75) Acdelco???
are the delphi 02 sensors as good as the acdelco? because i seen on the board that everyone says to use acdelco not bosch or any other ones,the website for delphi says they are the makers of acdelco? does any one use these(es10006)?
Old Nov 13, 2004 | 11:29 AM
Fbody1's Avatar
anyone?
Old Nov 14, 2004 | 06:24 PM
Fbody1's Avatar
does anybody use these?
Old Nov 14, 2004 | 10:37 PM
Huntr1117's Avatar
I used to work for O'reily Auto parts and we started replacing our Delco parts with Delphi parts. They said that they were exactly the same as the Delco parts and they had a better warranty. They also said that they were shipped from the same company.
Old Nov 15, 2004 | 06:44 AM
slopokrodrigez's Avatar
Went to that web site and I'm convinced it's the same part. But I'm still going to investigate it. In the last class we had for sensors, put on by Standard Auto Parts. That's the parts in the blue box. They informed us that they make most of the OEM and many of the aftermarket sensors for various manufacturers.
If you notice things like your OEM alternator have Delphi printed or cast right on them. AC Delco and Delphi are under the same umbrella of companies. I believe all the OEM radios are made under the Delphi name as well.
If I were you, I would ask this company getgmparts, if the part does not function properly, can you return it. Can you get your shipping charge back if it does not. How long do you have to return it and are there any rules to follow like in the original packaging and so on.
Good luck it looks like you're on to something.
Dave
Old Nov 15, 2004 | 06:56 AM
Fastbird93's Avatar
I'm going to agree with Slopok here.
http://store.getgmparts.com/es10006.html
If you look at the alternate part numbers, part number 25312184 is the EXACT part number that I recently purchased off of Jason Cromer for $37.00 each.
Now the only question is will www.getgmparts.com rape you on shipping like GMPartsDirect will??
*Edit*
I just played with the checkout there, and for 1, 2, or 5 of the above mentioned O2 sensors, shipping was a flat $10.00. That could definitely work out to be cheaper. One sensor was $37.88, which if you bought one off of Jason Cromer for $37, you'd have to only pay $.88 for shipping.
Good find!!
Old Nov 15, 2004 | 07:52 AM
Cmr0z28's Avatar
Thanks a bunch for this....I was just gonna order new O2's this week
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
