Delphi (MSD) 55, 65 or 75lb Fuel Injectors, Low Impedence?
Old Mar 23, 2004 | 06:22 PM
Formula Fbody's Avatar
Has anyone tried the Delphi (MSD) 55, 65 or 75lb Fuel Injectors - Low Impedence. How do these injectors work at idle? I see that you can use these with the stock computer. If you have used them please let me know what you think of them?
Thanks,
KEN
Old Mar 24, 2004 | 06:11 AM
IDOXLR8's Avatar
What kind of application do you have that needs that big of an injector? If you are going to run a low impedance injector with your stock computer than you will need an Acceleronics impedance convertor. Remember you will need to have your computer reprogrammed to run that big of an injector. For a blown application I like Siemans over MSD.
Old Mar 24, 2004 | 07:38 AM
Live for TAs's Avatar
I have not bought new injectors yet, but will second the above post based on my research. I'm looking at a set of Siemens 57# units. Check here & at ls1.com in the tech threads about the MSD injectors vs. the Siemens. The Siemens are also available as high impedance, which will work with your computer. The MSD ones will not work w/o a converter (extra $) and cost the same.
Old Mar 24, 2004 | 08:31 AM
kmook's Avatar
Advanced Tech Moderator
Only high impedance injectors will work with the stock computer without a impedance converter. The largest high imp injectors i've ever seen are those 57# Siemens.
Old Mar 24, 2004 | 10:55 AM
HungryT/A's Avatar
Just on a sidenote.
My friend used to run #50 high impedance injectors on his Syclone. Then he switched to #50 low impedance ones with an imp. converter and he said it's night and day difference. He had a hard time dialing in the idle fueling with the high imp. injectors, the stock computer simply couldn't control these big injectors efficietly, now with the low imp+converter his idle is *** smooth as silk.
hope this helps
Old Mar 24, 2004 | 11:54 AM
Low impedance (peak and hold) injectors are used for a reason. They operate much faster (1.0-1.5mS faster than high impedance/saturated), are more accurate and more consistant.
AdsoYo
May 2, 2018 03:21 AM
RUENUF
Mar 13, 2016 03:39 PM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
