Delco spark plugs
Old Jan 31, 2007 | 02:56 PM
Bobsep84's Avatar
Delco spark plugs
I am looking into replacing the plugs in my LT1....and also the 4.3 in my van. From what i hear its always best to go with factory plugs...but i have heard that the platinum tip on the Delcos comes off Is this true and if so should i use different plugs.
Old Jan 31, 2007 | 03:10 PM
2000GTP's Avatar
When I pulled my old platinum plugs, all of the pucks were missing leaving the gaps in the .080 range. I have since opted for the copper conductor NGK TR-55s so I know longer have to deal the platinum pucks issue. They work just as well as the factory spec plugs in my opinion.
Old Jan 31, 2007 | 03:31 PM
BUBBA's Avatar
NGK, SIE. DELCO PLATS, NO.
Old Jan 31, 2007 | 03:40 PM
slo_z28's Avatar
they will with n20, lol. But really, delcos are good plugs. Stick away from bosch!
Old Jan 31, 2007 | 04:14 PM
Bobsep84's Avatar
LOL I wouldn't touch the Boschs with a 10 foot poll Looks like im gonna be picking between the Delcos and NGKs. I don't intend to use any N20....would the pucks still fall off the Delcos even without N20?
Old Jan 31, 2007 | 04:17 PM
slo_z28's Avatar
I have always run NGK TR6's (stock displacment + spray) or TR5's (385 + spray)
Old Jan 31, 2007 | 04:42 PM
Bobsep84's Avatar
Do you use the copper ones or the irridium ones?
Old Jan 31, 2007 | 04:49 PM
slo_z28's Avatar
Copper, Iridium is n20 safe but copper conducts better
Old Jan 31, 2007 | 05:13 PM
Bobsep84's Avatar
I would probably use the Iridium ones tho because im lazy and don't want to change them all the time
Old Jan 31, 2007 | 06:42 PM
2000GTP's Avatar
Using nitrous won't cause the pucks to fall off on the platinum plugs. Its not even advised to use platinum plugs and spray anyhow. And yes, if you don't want to change plugs as frequently, go with the iridium, they will cost a little more though.
Old Jan 31, 2007 | 08:47 PM
I lost the pucks off two sets of Delco stock plugs... one set when I wasn't running nitrous, and one set while I was. I would suggest the NGK's.
Old Feb 1, 2007 | 09:42 AM
NJ-LE's Avatar
Question
Excuse me for intruding but I have a set of Autolite AP104 plugs I was going to install. Have they had a problem with losing the Platinum puck?
Old Feb 1, 2007 | 11:18 AM
multicar's Avatar
No, don't think they have a puck like the delco's and they are alot cheaper. I've run them for 36k miles, and they need changed, but I'm waiting for warmer weather.
Doug
Old Feb 1, 2007 | 11:48 AM
2000GTP's Avatar
Those Autolites have copper conductors and do not have the pucks.
Old Feb 1, 2007 | 12:31 PM
I've been running AC-Delco Rapidfire plugs for years without issue. I can't tell that they have any pucks on them.
