Deep Creep and opti vent hole
Old Mar 16, 2007 | 02:12 PM
Texas_96_Z's Avatar
I am considering a seafoam treatment this weekend. I know about the brake booster way of getting seafoam into the upper motor. What about spraying deep creep into the opti vent hole at idle. Would that get in the upper motor more uniformly than the brake booster?
Old Mar 16, 2007 | 02:16 PM
96capricemgr's Avatar
You mean in the elbow in front of the TB right?
I would worry about it pooling and most of it going through the IAC.
If you unplug the MAF and disconnect the elbow you can run the motor with the elbow off. It will set a CEL for a failed MAF but it will run so you could spray that at the blades.
If the MAF is functional and plugged in and you try to start the car with the elbow off I do not think it will start.
I am glad too see someone else who can plainly see the brake booster trick will only hit a little bit of the intake.
Old Mar 16, 2007 | 11:26 PM
Texas_96_Z's Avatar
I would think that the motor sucks enough CFMs so that the spray would go directly through the blades and on into the upper motor. I suppose I could goose the throttle body to get the RPMs up while spraying, thus sucking in more air. What effect would this chemical have on the AIC? I did not know the motor would run without the elbow attached. Has anyone tried deep creep in the throttle body while the engine was running?
Old Mar 17, 2007 | 12:16 AM
93v8clone's Avatar
it will pool up in intake at work when we do intake services we need to spay it right in the t-b or it wont go in to well dont seafoam it take it to a shop that supports b-g products and have them do it its a 3 step process 1 cleaner threw fuel rail 1 in the throttle body and 1 in gas tank works really well
Old Mar 17, 2007 | 08:48 AM
I would just be concerned with it sludging up the IAC with all the crap it knocks loose that is why I would not spray it through there. You would be amazed how little air goes around the blades at idle.
Old Mar 17, 2007 | 08:49 AM
moparman's Avatar
Don't use Deep Creep to bust the carbon out of the engine. It's the wrong Seafoam.
Old Mar 17, 2007 | 09:17 AM
It is the same stuff just aerosol. Going through the TB I bet he gets better distribution thanthe brake boost most folks do with the non-aerosol.
Old Mar 20, 2007 | 09:08 PM
Texas_96_Z's Avatar
Talked to a mechanic and he says they use BG 44 for upper motor cleaning. I asked him how he would do my intake and he said he would probably just remove the IAT sensor and spray directly into the TB. I asked him is it ok to hose down the IAC, he said no problem. So for those who have used Deep Creep (the aerosal can of seafoam) how fine is the spray? Is it a fine mist or does it come out like a brake cleaner spray can?
Old Mar 20, 2007 | 10:13 PM
stopthatman's Avatar
like brakecleen
Old Mar 20, 2007 | 10:24 PM
LiENUS's Avatar
Deepcreep MIGHT tend to eat through the rubber of your elbow. I wouldn't spray it there
Old Mar 21, 2007 | 08:54 AM
pcgamer4life's Avatar
It seems you're a bit confused on what Deep Creep does. Deep creep is meant to be sprayed directly through your throttle body, not injected into the brake booster. If you're wanted to clean out the engine, do the seafoam treatment through the brake booster, the deep creep in through the throttle body, and a can in the gas, half a can in the oil. You can beat a $16 complete engine/fuel treatment. (each can is around $5) You're making it seem like you want to spray the deep creep in through your brake booster, which is probably a poor idea. First of all, the chemical will be in a much lower concentration since it's atmoized, pretty much defeating all cleaning purposes. Second of all, it'll be really tough to stall out your engine with an aerosol... you might want to read back over the tutorial.
Old Mar 21, 2007 | 10:54 AM
Texas_96_Z's Avatar
You need to re-read the thread. My question is about applying Deep Creep through the TB while the motor is running...
Old Mar 21, 2007 | 03:07 PM
Heatmaker's Avatar
Advanced Member
You can Deep creep the TB... but don't expect the same results as the Brake bootster.
Old Mar 21, 2007 | 03:31 PM
Texas_96_Z's Avatar
Originally Posted by stopthatman
like brakecleen
Well if it streams like brake cleaner I don't think it will work through the opti hole or IAT hole. I guess I will have to shut it down and disconnect the elbow and just hose the **** out of it that way......bummer.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
armedtrigger
Feb 24, 2015 08:30 PM
82 Pace Car
Jun 30, 2002 09:03 AM
