Decided to go with a GM sbc 400 bow tie block and dart pro 1 platinum aluminum heads.
Old Nov 3, 2007 | 02:07 AM
Kurt Crosbie's Avatar
I was going to go the LT1 396 route, but after analyzing my budget, and what I want, I will go the sbc route. I've already found the heads for $1120, the block is $1549, and the custom cam is $400. The heads come fully assembled with my choice of springs, which will be chosen after I get the cam ground. I will use the pro ram intake, and will stick to eagle rotating assembly at around 11.5:1.
I am not exactly sure why I posted this. Just very excited.
Old Nov 3, 2007 | 06:33 AM
95ltbird's Avatar
i heard that it is illegal to put an older engine in a newer car??? and what are you going to do about the transmission?
Old Nov 3, 2007 | 06:54 AM
CANTONRACER's Avatar
Make sure the valvetrain is good...some of the assembled jobs leave a lot to be desired.
Good luck.
Old Nov 3, 2007 | 08:32 AM
Yeah, you won't be posting in here any more, since it's not an LT1.
Old Nov 3, 2007 | 09:01 AM
Vicious95Z28's Avatar
, lol, yeah like that ever stops people.
Old Nov 3, 2007 | 10:27 AM
1racerdude's Avatar
Logical choice...
Do the heads flow in the 300+CFM range?
Why not convert the heads and run them on the LT1 instead of changinng the radiator? Cost is about the same.
Old Nov 3, 2007 | 11:19 AM
Thats a good question. Probably because of the versatility of the 400 block. I am getting the 400 block brand new for about the same price it would cost me to get an LT1 turned into a 4-bolt and blueprinted.
What would it take to convert the heads?
Old Nov 3, 2007 | 11:23 AM
mdacton's Avatar
that block still needs machine work
Old Nov 3, 2007 | 11:27 AM
Right, but what kind of machine work?
I figured all it would need is to be decked and I would want a little bigger bore for a 427 displacement.
By all means, please convert me back to an lt1 block.
Old Nov 3, 2007 | 11:29 AM
mdacton's Avatar
Whats the ultimate goal?
4 bolt mains is kind of over rated...I never seen a 2 bolt breal or fail b/c it was a 2 bolt.
One good thing about a LT1 is you can get by with alot more compression. You could run those heads converted to LT1 and a dome piston.
Old Nov 3, 2007 | 11:41 AM
urbaNHunter44's Avatar
best of luck on your swap, sounds like quite alot of work.
are you going carbed or fuel injected? what are you doing for the trans?
Old Nov 3, 2007 | 11:47 AM
1racerdude's Avatar
'Bout $300.00
The reverse flow cooling will let ya make more HP easier.
Haven't decided on fuel delivery yet. I am debating on the TH400 or TH350 trans. Do people still use M6's in the 10 second range?
Old Nov 3, 2007 | 11:49 AM
mdacton's Avatar
don't waste your time....noone makes a legal nhra bellhousing anyway
400 is a proven winner.
350 is too but it may or may not last....
Old Nov 3, 2007 | 11:52 AM
McLeod makes an SFI-rated modular bellhousing for the T56.
