Dead miss after rebuild (blowed head gasket)
Yes I had the fuses out and throtle wide open, something is bad wrong it has zero compression to the number 3, with all the other plugs out and a plug in number 3 it turns and never builds compression. I'll have to take the header off in order to check the number 5. I took the valve cover off and it has a white milky film of oil on the top of the cover, and the rockers look to be moving like the rest. when i say it has zero compression, I mean it has zero.
Thanks for all the help, it was a bad intake valve. I still don't understand how I blowed the pass side head gasket and burned the number 3 intake valve. Well thanks again, the miss is gone but I've got other problems, i'll just start a new thread.
