Dead Clutch can you ID these ?
Old Mar 18, 2003 | 05:29 PM
QUASARBLUEZ28's Avatar
Couple of months ago I lost all Clutch pressure to the pedal. I covered the car up for winter and today took a peek. I was hopeing for a messed up slave cylinder but when I pulled off the actuator this is what I found. I'am guessing a bearing failure and
clutch disc blowout.
Its a bit blurry. Anyone care to ID these?
http://community.webshots.com/script...ecurity=yoAerR
Couple of needle bearings and I am guessing a few DISC parts.
I had installed a New flywheel last year with everything else but my guess its going to be F'd too.
I heard about the Bearing/bushing thing after I put it all together last year and expect thats the root cause but then again I have the OLD STYLE Spec Carbon too. (at Least that under warrenty). I expect they will replace it with the NEW STYLE.
Anyone heard any issues with the newer disc's? I have not..
On the plus side.. I've done this before by myself so It wont take as long this time, plus I have a few other things to install as well.
Old Mar 18, 2003 | 05:31 PM
97Z-M6's Avatar
need to make the album public. i cant veiw it, olny the owner can and thats not me.
Old Mar 18, 2003 | 06:10 PM
Mikey97Z's Avatar
I had to really hunt for a shop with the brass bushing still in stock. Most around here seem to stock a needle bearing as the replacement for all years of camaro and vette.
I'm using the Spec StageIII Carbon with 6 pucks ind it is totally kickass. Here's a pic of the StageII Kevlar and new StageIII Carbon.
Old Mar 19, 2003 | 06:19 AM
Lets try this again. Its the last pic in the series.
http://community.webshots.com/album/33786390mmhudJ
I'll be in touch with SPEC once I get the old clutch out and go with the 6 puck design as a replacement. Brass bushing also, and hope my input shaft isn't screwed.
Old Mar 19, 2003 | 07:55 AM
95 Z/28 LT1's Avatar
Super Moderator
Looks like your throw out bearing came apart. Kind of tough to tell from the pictures though.
I would just replace that if you have already changed everything else.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
