Dead battery?
Old Jul 5, 2004 | 04:04 PM
ollie-99's Avatar
Dead battery?
my battery died the other day; and i got it jump started
i put a volti meter on the battery and it read 13.6 does that mean its charging fine and everything??
-Oliver
Old Jul 5, 2004 | 05:04 PM
Dave88LX's Avatar
That running or not?
Usually ~12.8V off, ~14.4V running.
Old Jul 5, 2004 | 05:17 PM
n2ceptor's Avatar
Most alts will put out 13.8 to 14.2 volts when running...Give or take...
Have your battery checked with a load tester..... This will show you if there is a cell going bad....
Old Jul 6, 2004 | 12:07 AM
ollie-99's Avatar
i got 13.6 w/ it running
Old Jul 6, 2004 | 12:24 AM
bdc95ta's Avatar
I was told that it's not the volts your battery reads it's the CCA that starts your car. Cold Cranking Amps. Is this right? maybe someone can chime in.
-b
Old Jul 6, 2004 | 12:26 AM
crAzy95z28's Avatar
im around 11.4-11.9 at idle and then when throttle around 1000rpms it goes up to around 12-13...dang pulleys
Old Jul 6, 2004 | 11:54 AM
bdc95ta's Avatar
just get the overdrive pully for your alternator. I got one, forgot what my exact volts are but there good.
-b
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
