car won't start, please help
Old Jul 5, 2004 | 11:43 PM
whitemusclez28's Avatar
my 94Z sounds like its not getting fuel so i thought it could be fuel pump, checked fuel pressure, checked pressure regulator, checked for injectors geting signal, they are, also checked for spark. i replaced 2 injectors with injectors out of a friends car and turned car over with fuel rail out of manifold, and no fuel came from injegctors, even though the injectors are getting power, and the injectors are from a working car. i ordered a obd1 cable and i have 3 different free programs to scan, i don't know exactly what to look for in a scan results, and i have no idea whats wrong with the car. any help would be greatly appreciated. thanks
Old Jul 6, 2004 | 12:15 AM
CamaroSS30thAnn's Avatar
Re: car won't start, please help
first thing...how was ur fuel pressure....were u getting spark....check ur fuel filter ...could be clogged
Old Jul 6, 2004 | 12:22 AM
bdc95ta's Avatar
here you go!
http://mainstreamtopics.com/forum/in...p?showtopic=78
thanks to hbhracing
Old Jul 6, 2004 | 05:28 AM
fuel filter is fine just replaced, and i am geting 44 lbs of presure at initial start then dropping to 3 or 4 lbs after a second or two, still receiving signal to injector, tested with niod light, and no wet fuel is found at vaccuume line off of fuel pressure regulator
Old Jul 6, 2004 | 05:29 AM
also receiving plenty of spark!
Old Jul 6, 2004 | 12:02 PM
bdc95ta's Avatar
read the last bit of that link I provided talking about if you have spark and fuel but no start!
-brandon
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
