de-sensitizing the knock retard
Old Jan 25, 2006 | 11:23 AM
wrd1972's Avatar
Is it possible to de-sensitize the knock retard system with a custom tune.
I though I once read that Ion can do this with his custom tune.
I may have just a tad of KR from the headers and RR's.
Old Jan 25, 2006 | 11:39 AM
RamAir95TA's Avatar
Re: de-sensitizing the knock retard
Before you go looking into this problem, why don't you make sure you have a problem first? Get a scanner on it.
teke184's Avatar
install an lt4 knock module...
do a search...don't know the price or PN off hand
Old Jan 25, 2006 | 11:42 AM
wrd1972's Avatar
I will be getting a Scanmaster.
Im just want to understand how to correct the problem ahead of time.
Old Jan 25, 2006 | 12:14 PM
Dave '97 Z28 M6's Avatar
As already suggested, the first order of business is to verify that you actually have KR. I use TTS Datamaster on a laptop with an AKM cable.
If KR shows up on the scan/datalog, you have to determine if it's real knock or "false" knock. Run some high-octane gas (use an octane booster) in the car... if it shows KR with 100 octane gas, you can be sure that it's false knock. If the KR disappears with the 100 octane, it's probably real knock occuring with the lower octane gas.
At this point, if you're sure the knock is not "real", you have several options:
- bypass the knock sensor with a resistor
- zero-out the "burst retard" table in the PCM
- reprogram the PCM to allow for a bit of knock before retarding timing
- totally remove KR from the PCM
Naturally, it is preferred to not completely remove the PCM's ability to detect knock, and protect the engine from low-octane gas, etc.
Old Jan 25, 2006 | 12:17 PM
RamAir95TA's Avatar
I agree with everything you said, minus the use of octane booster. They only raise the octane by tenths of a point. His best bet is to run a gallon or so of100-octane straight.
Old Jan 25, 2006 | 12:18 PM
wrd1972's Avatar
Can this test be done with the engine simply idleing or do you have to actually drive it.
Old Jan 25, 2006 | 12:43 PM
Thanks for the correction - I've never actually used the stuff myself.
You're going to have to drive the car, with a scanner/laptop hooked up, logging or monitoring the KR. You'll need to do a couple of full-throttle pulls through the full rev range (I do it in 3rd gear, from 1500-6500).
Old Jan 25, 2006 | 02:05 PM
speed_demon24's Avatar
Whats burst knock retard? I'm trying to solve my KR issues too...
Old Jan 25, 2006 | 02:38 PM
OBE1 95Z28's Avatar
Be sure to include shifting points in your log data. Common to get some knock during shifting.
Old Jan 26, 2006 | 11:45 AM
It's the KR that the computer dials in for a fraction of a second when it detects a sudden change in MAP, i.e. when you quickly open the throttle.
I'm not sure how much of an effect this has on normal KR, though.
Old Jan 26, 2006 | 01:19 PM
It doesn't keep getting KR if from burst does it? For example, yesterday, my car was running fine, then I decided to hit it in 2nd from 40mph, and I instantly got 5.0 degrees when I hit the gas, and it stayed at 5.0 degrees exactly the whole time I was at WOT..
Old Jan 27, 2006 | 01:04 AM
That's not burst retard. Like I said, though, I'm not sure if burst retard would make the PCM more prone to standard knock retard or not. I'm not even sure if "burst knock retard" is the correct term. I think the PCM can retard the advance for a fraction of a second upon a sudden large MAP reading change, i.e. when you snap the throttle open; and it will do this irregardless of input from the knock sensor/module. After that fraction of a second, the PCM will then base it's retard (if any) on readings from the KS/KM.
Hopefully someone with more knowledge will chime in.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
