Dash conversion idiot lights?????
Old Apr 25, 2003 | 09:38 PM
95droptopZ's Avatar
Question Dash conversion idiot lights?????
Just finished converting my 95 Camaro with a 97 dash and gauges. Everything works, but the Air Bag light, Seat belt light and the ASR Off lights are on. I have'nt hooked up the air bags electrical connections yet because I want to make sure that is the last step I complete. Does anyone think that maybe the seat belt light is staying on as an additional indicator for the air bags not being connected (BTW I did try strapping both seat belts in before asking the question)? Anyone on guesses with the ASR Off light? My car does'nt even have this option and I have no wire to connect to the instrument cluster harness for it? Hope someone can help! I'm tickled pink everything on the gauges works, but would really like to sole this little problem.
Old Apr 25, 2003 | 09:53 PM
scoobysnax83's Avatar
I know this doesn't help, but I wanted to do this a while back, but lack of information steered me away. if you have any pics or want to post some how to's it would be much appreciated. The 97 dashes are much sexier....Just my opinion
Old Apr 26, 2003 | 04:58 AM
95droptopZ's Avatar
Trying to get a list together so I can do just that. Right now I need to figure this out. Anyone?
Old Apr 26, 2003 | 06:52 AM
I think you're one of the very few that have done this. I don't really know how much of a response you're gonna get on this. But atleast this reply will send you 2 the top!
Old Apr 26, 2003 | 09:12 AM
Blue89Bird's Avatar
as for the ASR light, I would just remove it, if you don't have the option and no wiring for it, it makes no sense to have it lit up, but I'm sure you've already figured that out.
I would just plug the airbag in and remove the ASR bulb, got nothing to loose right? Then you're only left with one issue.
Old Apr 26, 2003 | 10:10 AM
95droptopZ's Avatar
I appreciate the help. The only problem with the light bulb option is that most of the indicators on the cluster are solid state electronics. Indicatore such as the SES, seat belt, ASR and others work off of internal circuits. After looking at schematics I'm wondering if on the 97 and up F bodies that have the ASR or TCS if there is always an indicator on showing status of the traction system. I know there is an ASR off light and an ASR on light, but are they both ever off (not lit up)? As for what scoobysnax83 was asking, for the conversion, you need the newer style dash and all trim pieces, the upper dash piece (goes from windshield to dash), the main HVAC ducting (large plastic piece), a small HVAC piece for the drivers side defroster outlet, the newer A pillar trim (convertible and T top are the same, coupe is different), 1997 guage cluster (this is the only year that will work with older wiring harnesses), 1997 and newer cluster connector (same one used on Firebirds from 1994 -2002), the trunk release button moves from the glove box (93-96) to under the steering column (97-02) it's the same connector and button so you just have to extend the wires, the fog light moves from the headlamp switch to the center radio/HVAC bezel and it also uses the same connector (different switch though) so these wires need extended also. The rear defroster moves to the HVAC controls and uses a new connector that requires only 4 wires instead of 5 (the gray wire is no longer used for lighting the switch as it has it's own internal circuit for this), you need to re-use your original connections on the rest of the HVAC controls (the rest of the electrical plugs in, the cable from the center dial bolts on and the right dial is the vacuum controller for operating all the "doors" in the system, simply screw the old controls onto the new HVAC plate and use the new dial (97 & up have lighted lines on the dials at night (the light is transferred through clear plastic from the illumination lights) and thats it for the HVAC controls), the new HVAC ducts screw in the same places as the old ones and hook right up to the existing duct that is mounted to the firewall (gotta love the engineering at GM),. I did this to a 1995 Camaro and my original passenger side air bag bolted right up with no problems, the glove box latch is the same for all years on Camaros so just remove it from the old and put it on the newer glove box and your key will still lock it. The entire dash screws to the firewall at the same 5 points for all years. I did learn from the factory manuals that you need to disable the air bags fuse and actually unplug the connectors for them before doing anything with the dash (for safety), also remove the connectors at the base of the steering column for the brakes, cruise control ignition, etc. because you have to lower the column to do this conversion and those wires won't travel that far (they are all different connectors so replacing them is just trial and error until they all fit where they go). Removing the front seats would have helped and when putting the new dash in, I would recommend putting the dash metal support (thin metal part that runs the length of the dash on the bottom for support), then bolt in the passenger air bag and looosely have the main HVAC duct where it goes and put it into the car as a unit, then before bolting it all together is when you have to route the old wiring harness. Then screw the dash in and start putting all the little pieces back together. The last thing I did was put the wires from the old guage cluster connector into the new connector and plug it in to the new cluster. I have many of the GM part numbers for this and Scott and all the guys at Speed Automotive were very helpful. I also have the schematics and the cross reference for what wires go where.
Old Apr 26, 2003 | 10:28 AM
Blue89Bird's Avatar
damn, someone did there homework. I'd love to see some pics when you get the bugs worked out.
Old Apr 27, 2003 | 08:25 AM
95droptopZ's Avatar
Smile
Well I figured it out. I just removed the wire from the cluster connector for the seat belt light and that took care of that. Hooked up the air bags and that light went away. Then I added a wire for the ASR in the cluster connector and grounded it, and presto no more ASR off light. I'm still curious if anyone out there with a 1997 that has the ASR or TCS option has a light on thier dash showing whether the system is on or off all the time or if it is ever just not indicated (no indicator light showing at all)?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
fpete1992
Dec 11, 2014 03:51 PM
