Damn Fuel Lines!!! Give Me Some Help.
Old Jul 9, 2003 | 09:18 PM
MeanGreen97Z's Avatar
I have a 1993 Z28 and I cant get the damn fuel lines off the intake. I got those plastic fuel line removers from the local auto parts store and they get the smaller of the two off but the larger line doesn't budge. Give me some help! LOL
Old Jul 9, 2003 | 09:56 PM
silverz28's Avatar
Push the plastic tool inside the fuel line. Then, push the fuel line towards the plastic tool. Then, pull the plastic tool and fuel line off together simultaniously. Hope this helps.
Old Jul 9, 2003 | 10:06 PM
...and give a little twist...
Old Jul 10, 2003 | 01:35 AM
Zepp's Avatar
Make sure you are using the correct size disconnect tool.
Old Jul 10, 2003 | 06:26 PM
I have done this before but for some reason on this new car the 2 fuels lines are different sizes. On my 97 both were the same size. Now using 2 different size tools. I have tried everything and only gotten one to come off. Damn these little cheap *** o reilly tools!
Old Jul 12, 2003 | 10:55 PM
TTT
Old Jul 12, 2003 | 11:11 PM
There is not much more advice to give. I used the Lisle tool and it worked pretty well.
What silverz28 said is just the way to do it.
Old Jul 13, 2003 | 12:39 AM
craigffb's Avatar
I just pulled mine off today and the larger one (the one in front was a little harder to get off). Just do what silverz28 said. That's the way I got mine off.
Old Jul 13, 2003 | 10:18 AM
PoorMan's Avatar
I would try not twisting it first. I twisted and pulled and it twisted two of the four tabs that locks the fuel line on. Not a replaceable item unless you replace the fuel line. I will never take the rail off again.
Jeff D.
Old Jul 13, 2003 | 12:29 PM
Jeff D.
Yeah, you don't twist it first. You twist a little after the tool is inserted and the clips have been retracted. This is to free it, if it is stuck on the end of the tube.
Old Jul 13, 2003 | 01:29 PM
DjArcadian's Avatar
I had to use a different brand of fuel disconnect tools. The one that worked was by Lisle. The same one shoebox used. I spent weeks trying to get it off and then switched brands and it worked within 30 seconds.
Old Jul 13, 2003 | 02:19 PM
PatriotTA's Avatar
Same crap happened to me. I used those multi-colored ones by OEM or Performance Tools or something like that. Wasted a whole night. Next morning bought the white Lisle set and got them off in about 10 seconds.
87Aerocoupe
Mar 20, 2015 01:23 AM
DetroitZ28
Feb 13, 2015 07:33 AM
Deadbolt24
Jan 19, 2015 01:29 PM
Jul 4, 2005 05:00 PM
