D@MN Intake Bolts need help asap!
Old May 20, 2005 | 08:49 PM
Heatmaker's Avatar
Advanced Member
I got a little anxious when taking apart my intake... and forgot which bolts go where. I know theres extended thread studs, and just regular bolts... but which bolts go to which hole? can anyone help me?
Old May 20, 2005 | 10:16 PM
bluezed28's Avatar
Re: D@MN Intake Bolts need help asap!
yo yo yo. Try this exploded view out, it should help you on some and use the process of elimination for the others. BTW, don't force anything, take your time
http://shbox.com/ci/intake_bolts.jpg
Regards,
Old May 20, 2005 | 10:53 PM
Lt1t56's Avatar
As you can see in the picture, GM has some bolts with studs on top that arent used.
On the passenger side, the 2nd one from the front is the alt bracket stud, the 3rd one is the wire harness holder.
On the drivers side, the 4th one from the front is for the accel cable bracket, the 5th one holds the egr solenoid.
Old May 20, 2005 | 11:04 PM
Another reference on my site.
Old May 21, 2005 | 12:23 AM
Spinner's Avatar
I used bolts in every hole. Studs were always a PITA. ARP makes a nice 12 point stainless set.
Old May 21, 2005 | 10:20 AM
Heatmaker's Avatar
Advanced Member
Thanks you guys are awsome!
Old May 21, 2005 | 11:46 AM
94zgreenmachine's Avatar
Originally Posted by shoebox
shoebox,
Whats that brace coming off the drivers side. I only have 4 studs total. 2 on the drivers side ,holes 3 &4 and holes 2&3 on the passenger side. NO brace at all though.
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
rcajun86
Jan 30, 2015 01:56 PM
thenewkid
Nov 27, 2014 09:41 AM
