Cylinder hone, (street engine vs race engine)
Forgive my elementary question please.
Do you cylinder hone (mostly street some strip) engines differently than (strip occasional street) engines?
~300 hone stone then plateau for street?
~600 hone stone then plateau for race?
Or is it specific per ring manufacture?
Thanks,
Karl Ellwein
Thanks,
Karl Ellwein
Re: Cylinder hone, (street engine vs race engine)
Thanks,
Karl Ellwein
Thanks,
Karl Ellwein
Rich
Thanks Rich,
Seems like I can't go wrong to do it as per ring manufacture specs.
So, very related to my original question....would a 600 finish hone with plateau finish finish not work well for a street engine?
Karl
Karl
Thanks guys for the info and the links. I'm still trying to see if I can get a general statement from engine builders here...
Do you hone a race engine in any way differently than a street engine?
thanks,
Karl Ellwein
thanks,
Karl Ellwein
thanks,
Karl Ellwein
thanks,
Karl Ellwein
FWIW, finding an EXCELLENT block shop is not an easy task. There are some, however. If you really want the block prepped well, expect to spend over $1000.
"You don't always get what you pay for, but you RARELY get what you don't pay for." -- The Old One
Originally Posted by A/G
Obviously, that figure does not include a cost breakdown of individual operations included, although it leads one to conclusion boring/honing must carry a high price tag. With due respect to OS, fortunately that is not true. The link provided above, is as unbiased as I've seen. It certainly adds credibility to what Steve Rands 'preached' at least 30 years ago. He was a guy that did his 'homework',with it dismissed by so called experts in the field to this day, obviously for political reasons, (read personal gain). He did his reseach thoroughly before putting it in print. BTW, yea he was an engineer as well as the president.
If you use a boring bar which locates off the deck and centers itself in the existing bore, you don't have much assurance the bores are where they belong. That's less expensive of course than having the block CNC machined. Just measuring a bore anywhere near the accuracy discussed in the link isn't easy, nor is the equipment cheap.
I guess it depends on how good you want your engine to be. Going back to the original thread question, if you have a bore that's pretty much in the right place and relatively round, you can help it some during the honing without spending much extra. Honing doesn't correct gross shape errors, nor does it move the bores. It's sorta like bodywork and painting a car. If the bodywork isn't great, the paint job won't fix it.
What would you consider a fair price for JUST boring and honing to excellent tolerance/finish? If it's a serious power engine, you might be converting to 4-bolt steel caps. Now it gets important that these are installed, bored and align honed correctly. Here's where some of the cost occurs, but without a good job here, where everything starts, your painting over wavy sheetmetal.
My $.02
No, it doesn't come at a job shop price, but not necessary to spend NASCAR dollars either. Comparing 'job shop' work to a CNC machined block is a big jump. 95% in the middle was omitted. No one here should go to former, and no one here needs the latter. With the subject focusing on honing itself, and in regards to above link, I was referring to Brush Research Mfrg with the Rands reference.
Here's a shop I recommend.
http://www.cncblocksnortheast.com/
Flex hones (Brush research) aren't used to generate a bore's geometry or even size it or generate the "furrows". They are used to plateau the surface, much like a farmer flattens the tops of his plowed furrows. If you don't do all the previous steps correctly, you've wasted you money.
NASCAR dollars for block prep are in a different league from what is being discussed here, but the idea of getting the bores where they belong and as close to true cylinders as practical ($) should be basic to any serious block prep. How close? How fa$t do you want to go?
Gary,
FWIW to get a LT1 block preped up to around "Cup Style" standards of having everything correct it's around $2000K to do. That's putting bores, decks, mains, lifter bores, cam tunnel etc.. in the right place at the right sizes.
FWIW i've had a few blocks done with a 220/280/600 and a very light cut with the 600 at that, and they come in pretty rough on the Ra, Rz readings. Basically you just don't want to go too fine or you will have more friction and less oil on the rings since the Rz is not deep enough.
Bret
Bret
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
