cylinder Head
Old Nov 12, 2007 | 05:50 PM
lt1loudmouth07
Guest
Posts: n/a
cylinder Head
How many head bolts are there on the driver side head
Old Nov 12, 2007 | 05:52 PM
mdacton's Avatar
17...why do you ask?
Old Nov 12, 2007 | 07:40 PM
OBE1 95Z28's Avatar
17 is correct, here's a nice drawing from Shoebox's site: http://shbox.com/ci/head_assy.jpg
Old Nov 12, 2007 | 07:48 PM
lt1loudmouth07
Guest
Posts: n/a
head
because i need to get my driver side cylinder head off so far i have the intake manafold off and the coil bracket and the rockers and lifters. u mean to tell me there are 17 bolts on 1 cylinder head. do i have to take those bolts off that held the lifters on
Old Nov 12, 2007 | 07:50 PM
mdacton's Avatar
no, you don't have to take the coil and all off either. Take the exaust manifold off.
short bolts on the bottom of the head....long ones under the valve cover area.....2 middle lenght ones in the recessed area on each end
Old Nov 13, 2007 | 08:18 AM
lt1loudmouth07
Guest
Posts: n/a
Head
Ok now all that stuff is out of the way. What are the torque specs on the stock head bolts and what bolts do i start first i am being very carefull because this is the first time ive taken a head off i just pray to god i can get everything back on smooth. i have the arp bolts i just bought. and also what kind of headgasket should i use?
Old Nov 13, 2007 | 10:17 AM
lt1loudmouth07
Guest
Posts: n/a
head gasket
are the felpros good gaskets to use for the heads
Old Nov 13, 2007 | 10:21 AM
mdacton's Avatar
for what? regular driving? yeah they will be fine.
Don't know stock specs......start in the middle and go outward in a circle. Lube your arps(or read the instructions and do what they say)
I'm sure shbox has the torque specs on his site
Old Nov 13, 2007 | 10:30 AM
This might help...
Old Nov 13, 2007 | 10:50 AM
lt1loudmouth07
Guest
Posts: n/a
Heads
So i will torque all the bolts down to 65lb. and yes my car is just used for normal driveing i am only doing the driver side because i have 2 bolts that broke off in my head from the headers. And shoebox in that picture labeled with numbers do i torque them down in order from 1-17
Old Nov 13, 2007 | 11:08 AM
mdenz3's Avatar
Yup start at "1" and go to "17". I would recomend going in steps. ie. torquing them all in seqeunce to 45, then 55, then 65 ft lbs (or what ever TQ spec ARP recomends).
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
