cyl heads and cfm #
Old Feb 6, 2004 | 08:20 PM
  #16
got_hp?'s Avatar
hey steve.......i shot you an email with some questions......get back to me when you get a chance, thanks.
Old Feb 8, 2004 | 12:28 PM
  #17
Schurters LT1's Avatar
Squinn are you running a HR or SR cam in your car .....intake ....what pcm/tuning what kind of power are you making at the wheels ...is this pump gas.....
still looking for people runing the biger AFR stuff thx
Old Feb 8, 2004 | 06:39 PM
  #18
squinn's Avatar
Old motor made 581 on the engine dyno, we ran it on 100 oct to be save, it was 11.8 cr. My new motor dose not fair wellon the dyno , tall gears, slicks, big stall conv, it put down 442 @ 7500. But if you go by ET MPH its making 630 hp.
Old 350 was HR, new motor is SR and runs on 110 oct
FAST ECM tuned by myself
Running my own intake ,
http://home.wideopenwest.com/~squinn0039/ltx.html
Old Feb 8, 2004 | 07:21 PM
  #19
This intake off your's care to talk about it a bit here ..... as to where you have made it better then the stock LT1/LT4 intakes....and it's power over a swap.....
Why have yo stuck with the LT1 heads as to going to a set of AFR heads ....are you makeing up the power with the intake or is it because of the big stall/gears that kind of stuff...
Old Feb 8, 2004 | 09:28 PM
  #20
squinn's Avatar
Main reason modifying the intake was to increase plenum, I also made the entrance to number 8 cylinder much better then stock. We did dyno testing on another motor of mine we had seen a gain of over 20 hp above 7k, this was a 560 fwhp motor.
As to why I'm still using the stock LT1 heads, money, as it would cost me over 6k to switch.
The reson this car goes as fast as it dose, its not just one part, its the whole combo being matched.
Old Feb 8, 2004 | 11:44 PM
  #21
So no real dif in intake under 7k so it real would not be need untill that point.....who do you get to do your cam's...
thx
Old Feb 8, 2004 | 11:49 PM
  #22
simple's Avatar
yes tell us everything damnit
Old Feb 9, 2004 | 05:52 AM
  #23
squinn's Avatar
I'll get out the dyno sheets tonight, it pick up everywhere, just the most over 7k
Old Feb 9, 2004 | 06:23 AM
  #24
Still looking for flow numbers.....is there any more people runnign this fast with the stock head.....how comw so much to change 6K ouch
Old Feb 9, 2004 | 10:03 AM
  #25
airflowdevelop's Avatar
Why the big interest in flow #'s? Do you know something everyone else doesn't?
what you are attempting to do is very simple.... you need to find someone you trust, that is capable of taking care of you...and proceed. don't concern yourself with advertising.
BTW...Steve is 100%....you can do everything you want with stock castings...
Dennis
Old Feb 9, 2004 | 10:20 PM
  #26
No i don't have a clue on what the heads flow nor do i no anthing about porting heads ...Just want to no...later down the road when i go stocker what heads to go with ....it is just info for me in the furture......
thx
Old Feb 10, 2004 | 09:14 PM
  #27
squinn's Avatar
3k for heads, 1k for t&d setup, 2k for custom headers, also a new intake and pistons will be needed, so its more like 7 or 8k.
I found all but the dyno sheet I need, still looking, thats what happends when you move.
Old Feb 10, 2004 | 10:52 PM
  #28
OUCH other then money why not go to a big head..and if so with one keep this 23* stuff LT1.....do you have any info on the big AFR heads and the pro's and con's of each...like what would happen if you put the 210's or 220's on the car.... keep your intake i know there is other changes here put just bare with we here go go with it
thx
Old Feb 11, 2004 | 05:40 AM
  #29
squinn's Avatar
Money is the only reason I have not changed over, but when I do hopefully next winter it will not be an afr head.
Old Feb 11, 2004 | 06:13 AM
  #30
racer7088's Avatar
Thumbs up
The heads get bigger and bigger and flow more and more to the 227 which can go 325 or so on a real flow bench depending on who ported it. It can make 700hp on a race engine and probably 650 on a street engine on pump gas.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
