Cyl. Head bolt torque specs
Old Jan 9, 2006 | 01:50 PM
BlackScreaminMachine's Avatar
Question Cyl. Head bolt torque specs
In the coming month, I am removing the heads from my LT1. I have done this before but I unfortunately forgotten the the torque spec for the head bolts. I have ARP head bolts already.
I am NOT looking for torque to yeild specs (in degrees).
I am looking for the ft. lbs. rating. It is in 3 steps. I have the pattern, I just forget the torque specs for each of the 3 stages. Anyone that has them, please post or where I can find them.
Old Jan 9, 2006 | 02:11 PM
89LT1Formula's Avatar
Re: Cyl. Head bolt torque specs
25, 45, 65
Old Jan 9, 2006 | 03:16 PM
ok man thanks. I knew it was something like this. I just forgot. Unless anyone else has a different opinion I am going with this.
Thanks again!
Old Jan 9, 2006 | 05:59 PM
cehan's Avatar
According to the instructions in the ARP head bolt box, aluminum heads are to be torqued to 60 ft. lbs. using ARP lube under the head and washer and ARP thread sealer on the threads.
Chris
Old Jan 9, 2006 | 06:12 PM
OBE1 95Z28's Avatar
Cehan has a good point, torque values change if you use ARP lube vs motor oil as a lube. You also want to chase the threads in the block so as not to get a false torque due to binding.
Old Jan 9, 2006 | 11:08 PM
1racerdude's Avatar
I go through all with 1 heavy grunt and factory sequence,then come back over all of them with 2 heavy grunts and factory sequence and never had a failure.
Sound familiar?
Use the manufacturers spec!!!!!!!!
Old Jan 9, 2006 | 11:48 PM
OBE1 95Z28's Avatar
See the link below for a heads/cam install procedure. It includes a drawing of the head bolt tightening order.
http://afrashteh.com/guide/install.htm
Old Jan 10, 2006 | 10:07 AM
I Used ARP head studs and they speicfied 65. And the specs i gave were for stock head bolts. I missed the ARP part. Sorry about that. But do what the spec sheet says that came with your bolts. I always start with 25, 45 though.
Old Jan 10, 2006 | 12:10 PM
foggedz's Avatar
What is the part number for the ARP head bolts?
Old Jan 10, 2006 | 12:37 PM
My motor was a Nu-tek motor already assembled when i received it. I recall a similar torq spec i just didnt recall the actual spec. I did one head 2 years ago and not a issue with it all all. I used sealant and the supplied washers.
Old Jan 10, 2006 | 08:08 PM
cehan's Avatar
ARP 134-3601
Chris
Old Jan 11, 2006 | 05:52 AM
Joe 1320's Avatar
The stepped torque is the way. It is time consuming, but worth the effort.
Old Jan 11, 2006 | 08:08 AM
I agree, especially with aluminum, if it isnt torqued in steps and the only time you can take a break is when one step is done. otherwise you can warp the head and it will never be right.
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
