Cutouts Dangerous
Old Nov 8, 2003 | 05:34 PM
Tair's Avatar
Exclamation Cutouts Dangerous
I have seen pictures of people installing cutouts after the cat, yet in front of the rear axle, on LT1's. In a few of the pictures it looks like the hot exhaust gases have TOASTED the bottom of the cars REALLY badly. I still think I want to use this location because of the great ground clearance it would provide, but I just wanted to know if extensive use of the cutout would be a hazard.
Old Nov 8, 2003 | 05:36 PM
bunker's Avatar
No thats not burns you see, thats just carbon deposit, go back there with a rag & it looks like new, by the time the exhaust gasses come out of the cut-out they are just warm not hot, mine after a year was real black, I took a cloth to it & it looks like new
Old Nov 8, 2003 | 05:37 PM
Transamdriver's Avatar
Mine would have blown up a long time ago. You can see all the black spots from my different stages of exhaust. First I cut off the stock muffler under the rear and it went like that for a couple months, then I went open stock ypipe, then open hooker LTs, then open Mufflex ypipe. And now the cutout under the pass rear seat.
Old Nov 8, 2003 | 05:38 PM
grendal's Avatar
Yep, it's just carbon/soot. Not burns. You can put your hand in front of the exhaust... it's not THAT hot.
-Michael
Old Nov 8, 2003 | 05:41 PM
Tair's Avatar
Alright, that makes sense. I almost forgot to mention that the actual cutout itself in some pictures was orange...rust maybe? Does everyone's turn orange after a while? Thanks for the quick response guys!
Old Nov 8, 2003 | 06:24 PM
94 CAMRO Z28's Avatar
I dont think a cutout will ever get hot enough to turn orange. Unless the car is running wrong the headers shouldn't even be orange. The only way it would maybe be possible is if the cutout was mounted to the header at the collector and the car was running terrible. Even then I almost doubt it would get that hot.
Aaron
Old Nov 8, 2003 | 06:25 PM
FacelessZ's Avatar
Re: Cutouts Dangerous
Seafoam
Old Nov 8, 2003 | 08:00 PM
Tair's Avatar
Aaron
Sorry I wasn't specific enough. The cutout isn't glowing orange from the heat, I was talking about when the car is off...It looks like orange corrosion.
Old Nov 8, 2003 | 09:55 PM
Black_Z28's Avatar
I'm sure it's just rust. But there's an easy way to find out. If it's rust it will be rough to the touch. And you might be able to scrape a few flakes off. O
One way to fix the carbon problem is to turn the cutout towards the ground a little.
Old Mar 3, 2005 | 06:34 PM
blind527's Avatar
How are cutouts installed? I have my cat back system welded, and I need to know if they need to cut it and reweld it to put the cut out in. How much would this cost roughly? And you guys say put it before the over axle pipe?
HibachiZ28
Nov 6, 2015 12:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
May 21, 2015 01:04 PM
