Cutout on single cat car
Old Aug 17, 2004 | 01:35 PM
LT1Squirrel's Avatar
I called the shop today and my appointment is tomorow, but i still cant figure out where to put it....im totally set putting it before the cat, i dont really see the point of putting it behind it...but when i looked under today, i saw there was not enough room to put it there, now im thinking of ripping off the cat altogether, but dont really want to do that, cuz then i'd have to weld the shield back on somewhere ....where did you guys put yours?
Old Aug 17, 2004 | 01:50 PM
Camerone222's Avatar
Re: Cutout on single cat car
I am not sure what you plan on spending money wise, but here is a solution:
Have them put flanges on each end of pipe before and after your cat, with balled ends so it is a bolt on cat. Then get them to make you a pipe that is the length of where the cat is that also has flanges, so you can bolt it on. Now you can have the cutout in the pocket just before the axle, have the true straight pipe you are after and still be emissions legal (when you want to be)
Hope this helps
Cameron
Old Aug 17, 2004 | 02:13 PM
thats a really good idea ...but the thing is, i havent gotten the electric part of my cutout yet, probably gonna order it next month...how is access with that being there?(edit: can i reach under and undo the bolts?)...anyone else with an idea?
Old Aug 17, 2004 | 02:40 PM
Access is also very good. I'm not sure if you are talking about the cat or the cutout for access, but they are both good. I was going to have this done on friday, but I was almost late for work, but I am going back to have this done. I have 17" 5 spoke rims, and I can see my cutout through the holes when I bend down. I put my e-cutout on without jacking the car up, so It should be pretty easy.
Cameron
Old Aug 17, 2004 | 02:42 PM
Red96Lt1's Avatar
Wow, I couldn't do that on my car. Guess it just depends on where you put it. I have duals in the y pipe.
Old Aug 17, 2004 | 02:53 PM
I have mine right before the axle, and the exhaust is really close to the passenger side of the car, so I just set an old blanket down and bolted that sucker up there. Then I ran the power wire when I put on my alum. ds, and I had to jack it up for that, but he doesnt have an electric yet, so for his purposes, he doesnt have to worry about that yet.
Cameron
Queens94z28
Dec 20, 2014 09:11 PM
Dec 1, 2014 08:08 AM
USAirman93
Nov 24, 2014 03:37 PM
Elcojoe
Nov 17, 2014 10:27 PM
Skull Leader
Aug 10, 2002 11:01 AM
