cutout question
Old Jul 6, 2003 | 11:14 PM
ponykiller z28's Avatar
cutout question
ok i ordered this cutout (the kind with the cable) and it came in and was only for a 2" pipe... so now i gotta get a piece of 2" pipe and weld it into my exhaust to put the cutout in...
but i was wondering if the 2" piece would hurt my performance while the cutout was closed.....
also, when i close the cutout i can see light coming around the valve... how bad of an exhaust leak would this cause? would it be very noticeable?
Old Jul 7, 2003 | 12:11 AM
djk19's Avatar
You are going to do somthing dumb if you restrict your exhaust to a 2 inch. You should make it a 3 inch cut out and 3 inch pipe all the way back.
Old Jul 7, 2003 | 11:41 AM
EviLBoX's Avatar
I haven't heard anything good about those cable cutouts. As you noticed, it doesn't exactly provide the best seal when the cutout is closed. Plus the fact that it's only a 2" cutout makes it worse. I'd say either get an electric cutout or one you have to crawl under the car to use, just make sure it's 3".
Old Jul 7, 2003 | 11:44 AM
rpm4lalo's Avatar
Send it back and order a 3 inch.
Old Jul 7, 2003 | 11:55 AM
chevyboy_z28's Avatar
if you ordered it from summit youll have no problems returning it.
Old Jul 7, 2003 | 12:27 PM
Antz97ZNJ's Avatar
send it back and order yourself a 3 inch
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
lbrowne
Nov 13, 2011 04:25 PM
Chrisdude
Jul 24, 2002 02:25 PM
Camaro90RS
Jul 23, 2002 07:57 AM
