cutout and ceramic coating
Old May 29, 2006 | 05:28 PM
jamieSS's Avatar
Question cutout and ceramic coating
I have a 1997 camaro SS and i want to run an electric cut out. where do i run the cut out? after the headers or after the y pipe? I was also about to purchase a set of headers. I am looking at the hooker super comp shorty headers. I want to be able to run my catalytic converters. Want are some good ideas? Is it worth getting the headers ceramic coated?
Old May 29, 2006 | 05:33 PM
2000GTP's Avatar
Re: cutout and ceramic coating
The favored spot to weld the cutout is right before the rear axle. The Hooker shorties are a decent header and you can't go wrong with the MAC mids either. Whatever direction you go, coating is a good idea and worth the extra money.
Old May 29, 2006 | 06:14 PM
OBE1 95Z28's Avatar
I agree with the above post, place the cutout high before the rear axle (under the rear seat area).
Old May 29, 2006 | 11:23 PM
jamieSS's Avatar
so would i have to run one or two cut outs?
Old May 29, 2006 | 11:47 PM
fbodyboy's Avatar
You would have to run only one cutout, and for the coating you should definantly get it. My stainless steel shorties get way to hot under the hood in meer seconds. I strongly suggest anyone to pay more for the ceramic coating, its worth the extra money.
Old May 30, 2006 | 03:46 PM
2000GTP's Avatar
One will be fine, some people have used two though in the y-pipe to create a sort of "true dual" I guess.
Old May 30, 2006 | 04:24 PM
JDM-93_Z28's Avatar
Wouldnt you want to put the cut out right after the y pipe and before the cat?? This way u dont have to go through the cat....
Old May 30, 2006 | 05:07 PM
Rami08's Avatar
my electric cutout is right under the passenger side, following the y-pipe in place of the cat..its a bolt on so i swap it out for the cat when i go get smoged..sounds nice
Old May 30, 2006 | 07:21 PM
matt65's Avatar
Clearance?
Old May 30, 2006 | 08:39 PM
Rami08's Avatar
3 1/4" lowest point..
Old May 31, 2006 | 08:01 PM
jamieSS's Avatar
so there wouldn't be a noticable difference between running 2 electric cutouts than one?
Old May 31, 2006 | 08:36 PM
Birdman7389's Avatar
Lighter wallet? Might sound a little more like a true dual setup.
Old May 31, 2006 | 08:39 PM
jamieSS's Avatar
i want performance w/o breaking the bank! i just don't wanna pay for something that isn't going to be worth it! How much more power will you get from the ceramic coated super comp headers and the electric exhaust cutout?
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
blaze309
Sep 8, 2015 05:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
