cut out effects
Old May 11, 2004 | 03:34 PM
ddj19852003's Avatar
cut out effects
I have a flowtech cut out installed on my flowmaster exhaust It is the manual kind= non electric. Am i hurting my car by leaving it open all the time?
Old May 11, 2004 | 03:51 PM
madwolf's Avatar
It has been debated several times.... (if the low backpressure will hurt your valves) but I know TONS of people running them open all the time without any problems. I know I have done it before until I eventually got tired of it. You'll probably wear out your ears first, then valves, if it's even true.
Old May 11, 2004 | 04:00 PM
SantaCruz163's Avatar
I have a cutout open all the time on my car, it's located right before the muffler. I get popping some times am I hurting the valves?
Old May 11, 2004 | 04:02 PM
madwolf's Avatar
I really doubt it.
If the popping is on deceleration and/or light throttle, that is normal.
Old May 11, 2004 | 04:53 PM
JoeliusZ28's Avatar
You might notice some creaks for your interior plastic developing from the vibration... which is why I try to close mine as much as possible which is usually less than half the time
Old May 11, 2004 | 07:31 PM
ping0317's Avatar
you don't get pull over with the cutout open... I would imagine that your car is really really loud!
Old May 11, 2004 | 07:58 PM
If you are talking about me, my cutout is right before the muffler so it's no too loud, but on saturday mornings at 6am when I have to go to work I tend to drive my mom or dads car, just so I don't wake up the neighborhood So far I've never had a problem with the cops on th noise but I am going to cap it off (mom's request). So once I get the money I'll be getting a Magnaflow catback as well as a DMH e-cutout which will be right after the cat, won't that be loud
Old May 12, 2004 | 12:47 AM
nope havent had any problems yet with the authorities the cut out is only loud when accelerating so i try not to hammer on my Z when around law enforcers.
Old May 12, 2004 | 01:17 AM
IDAREU's Avatar
3 years and counting, I only close it for long trips. It's had no ill effects other than I think my hearing has deteriorated a bit.
Old May 12, 2004 | 01:34 AM
disco192's Avatar
Leave it open for long trips. You will get better mileage. IF you have an M6, then it will barely be noticable louder.
Old May 12, 2004 | 01:57 AM
neil350's Avatar
Itsa solid gain, my LM shakes the car a little, same with the ES Tranny mount.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
92_RS_305
Sep 8, 2015 07:47 PM
