Custom Y pipe question
Old May 27, 2004 | 11:45 PM
aforut's Avatar
Hey guys I just bought my jet hot LT's today and from what I have read here I should just get a custom y pipe made, but I have two questions:
1: When I go to the shop what diameter should the pipe be and what kind of steel if it matters?
2. Also without a cat will I not have enough backpressure and therefore lose power?
Thanks for the info!
Old May 28, 2004 | 12:57 AM
Xride's Avatar
need backpreasure for more power? who fed you that BS?
you dont want backpressure,
get 3" all the way to the back with high flow anything that your putting in the pipe.
Old May 28, 2004 | 01:03 AM
aforut's Avatar
I thought that some level of backpressure was necessary???
Old May 28, 2004 | 01:25 AM
Xride's Avatar
nessesary for what?
you want backpressure then dont install your headers.... you manifolds have lots of backpressure.... but as you know do not produce the most power....
shorties have less pressure, and produce more then the manifolds
LT's make more then shorites, and have less pressure then the shorties....
take what you want from that.
if you want backpressure run a 2.5" pipe instead of a 3"
also if you plan on keeping the car, and or live where the car gets wet then get stainless pipe, you'll save the meney later from not having to redue it when it rusts out.
Old May 28, 2004 | 08:30 AM
atljar's Avatar
twin 2.5 pipes arent going to hurt. Gives you better clearence too.
Old May 28, 2004 | 08:41 AM
Valkyn71's Avatar
I was under the impression that backpreassure helped with torque somewhat.
Old May 28, 2004 | 10:49 AM
Xride's Avatar
from where?
if you make a 2.5 or a 3" Y the header flanges are still the lowest point.
it wont give you more TQ but it can move it around a bit.
when I dynoed efor and after my cat back I didnt get much TQ 7 ft, and 11 hp, but it sure did make my tq curve longer and flatter.
Old May 28, 2004 | 10:30 PM
atljar's Avatar
The collectors will still be lowest point, but they are more centered over the wheels. The areas farther from the wheels will be most likely to hit because that area of the car doesnt "follow" terrain. (not sure if thats worded clearly)
in example.... Speed bump. Go over and tires rise over it and then fall. That likely is enough to clearance the collector flang. However the Y has nothing to lift the body over the bump b/c the front wheels have cleared and the rears havent hit it yet.
Anyways, i made the numbers in sig with twin 2.5 Y.
Food for thought....
Twin 2.5 inch pipes has total cross section of ~9.8 ci
Single 3 inch cat back only has ~7.0 ci crossection
SpeedJunkee
Jan 27, 2015 10:02 PM
CARiD
Jan 14, 2015 04:00 AM
ModdedNerd
Jan 1, 2015 10:56 AM
97 RedSS
Jun 10, 2003 07:58 PM
Brad 97z
Aug 10, 2002 09:58 AM
