CSI questions
Old Dec 7, 2003 | 10:03 PM
Heatmaker's Avatar
Advanced Member
CSI questions
1. Is it necessary remove the "Water Pump Shaft"?
2. What are the benifits if it's done or not?
3. Is that silver cap thing that comes with the CSI water pump the "Freeze Plug"?
4. Are any gaskets or sealers needed for the water pump or the complete waterpump assembly when being put back onto the engine?
Thanks...
Old Dec 7, 2003 | 10:11 PM
Larnach's Avatar
I removed it on mine, not very hard at all, I just took a punch through the lifter valley and punched it out towards the front of the engine.
I would assume a little less drag on the camshaft gear.
Yes that is the freeze plug that goes in.
Use some black RTV sealant around where the water pump mounts to the water pump housing, just place the water pump on there, wait 24 hours, then tighten it down. It will act like an o ring.
Old Dec 8, 2003 | 12:29 PM
Heatmaker's Avatar
Advanced Member
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
lbrowne
Nov 13, 2011 04:25 PM
BLUETOPTA
30
Sep 18, 2002 12:22 AM
baron4406
Sep 15, 2002 07:42 PM
