CSI electric waterpump keeps blowing fuse???
Old Apr 22, 2003 | 08:40 PM
95LT1Z28's Avatar
Question CSI electric waterpump keeps blowing fuse???
I just hooked up my CSI electric waterpump per Ken Lowrance's directions. When I went to turn the ignition on it immediately blew the fuse by the battery terminal. I am using the 15 amp inline fuse for the battery terminal and hooked up the "hot" wire from the relay to the ignition fuse in the fuse box. I hooked the grounds up to the black wire that is screwed into the chassis on the right side of the radiator. What would make that fuse pop instantly, a bad ground? I have heard some people say to hook up the relay "hot" wire to the AC/Cruise fuse instead of the ignition? Thanks for any help!
Jeff
z28cam1993
Sep 9, 2015 04:08 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
reww86
Aug 29, 2015 06:04 PM
