Csi
Old Dec 1, 2003 | 01:25 AM
Heatmaker's Avatar
Advanced Member
Csi
For anyone that used a dremmel to modify the Waterpump housing. I'm assuming you need to use the grinding stone. Is it possible to get the job done with one but or do I need more? What bit works best?
Old Dec 1, 2003 | 01:33 AM
Spinner's Avatar
Stone works... carbide cutting bit works better
Old Dec 1, 2003 | 01:40 AM
97WS6SCharged's Avatar
Diamonde carbide is the way to do it, unless you want to take all day.
Old Dec 1, 2003 | 01:43 AM
atljar's Avatar
carbide bit for notches, and sanding flap to go around outside circumfrence of pump a few times.
p.s. Dont flip when you see what a carbide bit cost for dremel
Old Dec 1, 2003 | 01:48 AM
Heatmaker's Avatar
Advanced Member
THe carbide bit egh....for some reason when ever I wear out a bit...Itake it back to Lowes and they refund me my money....Tee Hee
Old Dec 1, 2003 | 01:49 AM
Brandon 95 Z28's Avatar
I did it by hand file, lol. I used the stone age method and it took about 5 hours for all four notches, haha.
Brandon
Old Dec 1, 2003 | 01:56 AM
Heatmaker's Avatar
Advanced Member
http://www.amazon.com/exec/obidos/tg...?v=glance&s=hi
This bit? It says it's not for metal though?
Old Dec 1, 2003 | 08:16 AM
mongse_1's Avatar
I used a stone bit, but I also used my die grinder that I use on heads/intakes. I think I used two bits, but it also took about 20 minutes.
Old Dec 1, 2003 | 10:02 AM
Spinner's Avatar
You dont want a wheel, you want a cutter bit. Like this.
Or this
Old Dec 1, 2003 | 10:57 AM
94formulabz's Avatar
No jest here,
I used two or three of the heavy duty cutting wheels sandwhiched together and it worked great. It probably says somewhere on the packeage not to stack them but it's worked well for me. I know some people hate the wheels because they always break them, you just have to make sure you are moving the wheel(s) in 1 flat plane.
-brent
HarleyZ28
Oct 5, 2015 06:23 AM
Indy93Z28
Mar 5, 2003 10:40 PM
T/A lt1
Nov 23, 2002 03:46 PM
Brian Demeter
Oct 4, 2002 06:35 AM
