Cruise Control not working
Old Feb 6, 2005 | 05:35 PM
fowler163's Avatar
Post Cruise Control not working
It just quit working all of the sudden. It worked fine that morning and didn't that evening. I checked continuity and voltage on the fuse, brake switch, cruise control switches, and wiring through the steering column. The cruise control module was plugged in and the cable linkage was ok. The only thing I didn't know how to check was the speed sensor on the tranny but it is plugged in. I have a 93 Z28.
Also I think my oil guage is messed up. One day I accidently left the switch on for several hours and when I looked at the oil gauge it was waaay past 80. Now whenever I first start the car it does that and then goes back down. The only problem is the readings are much higher than they used to be and it isn't as sensitive at is was. And when I shut the car off the gauge won't go back to zero anymore; it sits at about 20 or so.
I would appreciate any help.
Old Feb 6, 2005 | 05:46 PM
Z95m6's Avatar
Re: Cruise Control not working
subscribing, i'm having cruise control problems and want to know what you find out.
Old Feb 6, 2005 | 07:57 PM
tintagel13's Avatar
on my 94 z28 mine quit working when the third brake light went out...it's somehow tied into it...see if your brake light is out...
Old Feb 7, 2005 | 06:43 PM
fowler163's Avatar
same deal with me. Called the dealership today and asked them for some suggestions and he said make sure all my brake lights are working. I was thinking yea whatever that's dumb but sure enough my third brake light was causing the problem. I changed the blown out bulbs and everything runs fine. Dang Haynes manual only shows a "typical" cruise control system on the electrical syemactics. Note to self: don't trust Haynes manual.
At least it wasn't something major. I figure it's like Chevy's way of making sure you keep your brake lights working.
Thank you
Old Feb 8, 2005 | 05:36 AM
slopokrodrigez's Avatar
Both the cruise control and ABS will be disabled with a bad third brake light. It may be that way since both use the brakes to either enable or disable them. I came to realize it when I bought a new ss wing for the back hatch. It came with an LED third light which the computer does not see as a "bulb". Once I added a relay so the coil would simulate a bulb, it all came back to normal.
Old Feb 8, 2005 | 08:06 AM
96camaroz28lt4's Avatar
How exactly do you do this? I don't understand!
Old Feb 8, 2005 | 11:37 AM
rlax31's Avatar
Some people find replacing the turn signal shaft on the steering column fixes it. I guess they might go bad over time. Also might want to check the connectors on the pedals
Old Feb 8, 2005 | 12:04 PM
Koby's Avatar
My cruise doesn't work either. It blows fuses everytime i put a new one in, instantly. I never use cruise anyway...but it bugs me not having something work on my car.
Old Feb 8, 2005 | 12:05 PM
Joe Bellman's Avatar
I replaced the turn signal shaft on mine to fix the cruise problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Jan 6, 2015 11:52 AM
Collector Car
Jan 5, 2015 10:58 AM
SLIMJIM
Jan 7, 2003 11:06 AM
