Crossover tube bolts, What size thread?
Old Apr 3, 2007 | 09:32 AM
rickyzZ28's Avatar
I have a 95 LT1 and need to know what size the thread is for the steam tube crossover. I found 2 posts that give conflicting information. I used some calipers on my new bolt and it said that the bolt was a 1/2 x 18. I have also heard that it is a 3/8 x 18 nps. And one of the posts below says it is a 1/4-18 NPSF. Which one is it. Here are the links to the other posts.
http://web.camaross.com/forums/showt...ossover+thread
Old Apr 3, 2007 | 09:47 AM
mdenz3's Avatar
you are right it is a 1/2-18
Old Apr 3, 2007 | 11:41 AM
Brandon94Z28's Avatar
I just bought new ones this week from the dealership. They were 3.00 apiece. They must have changed the bolts, the new ones had a taller head, which makes r&r easier.
Brandon
Old Apr 3, 2007 | 11:48 AM
Spitfire557's Avatar
Brandon
yep, much more "grip space" on the new bolts, would highly reccommend replacing the bolts if you have the tube off.
Old Apr 3, 2007 | 12:52 PM
Originally Posted by shoebox
It's a special thread (1/4-18 NPSF) dryseal, straight pipe thread
Quoting myself, this info is straight from the parts book.
Measuring with a caliper is going to confuse you, because pipe thread fittings are larger in outside diameter. A typical 1/4' pipe thread fitting will be ~1/2" in diameter.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
