Crap I'm An Idiot!!!!!!!
Old Feb 8, 2004 | 07:26 PM
Heatmaker's Avatar
Advanced Member
Just realized my new Eaton posi isn't supposed to be used with Synth gear fluid! CRAP! CRAP! and Double CRAP! I used redline in there! G-danget! Did I mess my Posi up! This blows hella ***!!!!
I'm a G-dang Idiot!!!!
Old Feb 8, 2004 | 07:36 PM
94Sleeper's Avatar
I've had synthetic fluid (Valvoline Synthetic I think) in my rear end for 4 years. I changed over when I installed my Eaton, 4:10 gears, Raytech Crush Sleeve Eliminator and T/A Girdle. I haven't had any problems at all. Still hooks good and does not slip. I think you should be fine.
Old Feb 8, 2004 | 07:40 PM
BlackDog's Avatar
I don't think you hurt anything but, Eaton does say to reg. oil.
I have an Eaton as well but use reg. oil. They say this right on there web site.
Old Feb 8, 2004 | 10:58 PM
brokenz's Avatar
I actually called them up about this when I got my 12 bolt from Moser. I was told that it would weaken the bonding of the clutches over time. They also told me to run GM limited slip additive. When I first installed the rearend, I didn't have access to any so I just used two tubes of an additive from a local parts store. My outside tire would chatter like crazy on sharp low speed turns. I couldn't get some GM additive quick enough after that!
Not trying to get off topic, I'm just saying we all have those moments Heatmaker.
Does your posi still make both wheels spin? Unless you've been running a really long time then I doubt you've done any damage. Just change it out.
Old Feb 9, 2004 | 12:08 AM
Heatmaker's Avatar
Advanced Member
I spend so much time upgrading my car now..I hardly have a chance to drive it. I put 500miles on her with the new Posi in there. PArtially due to a 300 mile drive to Viginia....she should be okay if I change the fluid out right?
Old Feb 9, 2004 | 12:43 AM
brokenz's Avatar
I'd be willing to bet so. I'd change the fluid anyway now just to see how things are looking.
magman
Apr 15, 2016 03:08 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
jayblev95
Sep 26, 2015 09:44 PM
colts0455
Sep 22, 2015 02:03 PM
surreybrad
Jul 5, 2015 10:36 PM
