Crankshaft pulley installation
Old Aug 31, 2005 | 09:18 PM
redsick93lt1's Avatar
My brother forgot how the pulley was positioned when he took it off. Does it matter how it is installed as far as the crankshaft being properly balanced. I thought it just mattered in telling tdc but i figured i would ask you guys.
Old Aug 31, 2005 | 09:20 PM
LT1powered94's Avatar
Re: Crankshaft pulley installation
Its only for tdc reference. I've read if there are weights in the holes in the balancer then the direction matters, but it really doesn't make any sense. I wouldn't worry about it. If you have the time though, pull the #1 plug and verify TDC. Doesn't hurt to put it on correctly.
Old Sep 1, 2005 | 07:08 AM
JasonK94Z's Avatar
The crank pulley is only able to attach to the hub ONE way. The 3 bolt locations are not equally spaced from eachother.
Old Sep 1, 2005 | 08:25 AM
That is true. I always forget they come apart. I have three hubs/pulleys, all of them are stuck together. My post was assuming the pully was still on the hub.
Old Sep 1, 2005 | 09:02 AM
yes the pulley was still on the hub so it could have gone on so many different ways but we truned motor to tdc and then installed it. Thanks for the replys.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
Jason Short
Jan 19, 2015 06:34 PM
