Crankshaft Pulley Hub Help?
Old Aug 13, 2011 | 10:29 AM
gtstriker86's Avatar
Question Crankshaft Pulley Hub Help?
Hey everyone, i want to change the crankshaft seal on my 95 Z28. I know that you use a puller to get the pulley off, but im not sure on how you go about getting the hub off. Ive done some forum searching but im still a bit unsure on how to accomplish this task. Can anybody give some good step by step tips on how to remove the hub. Specifics on bolt sizes, (as ive read that you need to insert a smaller bolt into the crank as to not strip the threads). Pics would be a big help as I am a newbie
Old Aug 13, 2011 | 11:00 AM
RamAir95TA's Avatar
Re: Crankshaft Pulley Hub Help?
http://www.lt1engine.com/tech/remove...lt1-crank-hub/
Old Aug 15, 2011 | 01:38 PM
boostedz28lt1's Avatar
http://www.amazon.com/Lisle-Harmonic.../dp/B000P0XMKK
The tool above is for Removing the hub only, you insert a stud into where you removed the crank bolt from then use the 3 harmonic balancer holes to thread the tool into and then crank the big bolt down until the hub starts to slid off. I don't like to use and impact if i dont have to but sometimes it may be nessery.
To install you can go to the harware store and get a 7/16-20 threaded rod cut it down to size, Then you will need 2 bolts, a washer (should fit over the crank hub snout). Make sure the rod is threaded all the way into the crank and is not loose at all. Slid hub onto crank, then washer, then the 2 bolts. Slowly start to crank bolt and hub will start to slide onto crank. there will be 2 little grooves around the hub, the 2nd one in is where the crank seal sits.
Hope this helps and i have some pictures of the threaded rod method
Old Aug 16, 2011 | 08:48 AM
drennon1's Avatar
Also helps if you get the hub warm but not hot enough to melt the seal.
Old Aug 16, 2011 | 11:45 AM
You dont need to get the hub hot and that is a bad idea to say the least. do what has been mentioned and it will come right off and go right on
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
Slayer
Aug 17, 2015 03:55 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
