Crankshaft position sensor code broke?
Old Feb 11, 2004 | 10:51 PM
97silverTA's Avatar
The check engine light on my car just came on, and I scanned it. it said I broke the PO 336 code or something like that. The scanner said it was the crankshaft position sensor. What does this mean? Thanks for your help.
Old Feb 11, 2004 | 11:13 PM
There is a sensor on the lower RH side of the timing cover that keeps track of the crank. There is a problem with the sensor or maybe the connection. It won't have any effect on performance as it's only function on the LT1 is to detect misfires for OBD-II.
You might try resetting your pcm and see if the code comes back as sometimes a real rough road can cause it to hiccup.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
