Crankshaft hub install
Old Sep 11, 2006 | 09:00 AM
00JoeZ28's Avatar
Anyone know of a quick method of installing the hub to the crankshaft? I've been trying and it only goes on so far and then it's like I'm fighting to turn the socket, so it can be sucked up to the snout. Is their a special tool I'm misssing. Please help!!!!
Old Sep 11, 2006 | 09:15 AM
mmmchickenboy's Avatar
Re: Crankshaft hub install
make sure the crank key is sitting in the crankshaft correctly, and make sure the slot in the hub lines up with the key.
EDIT: im retarded and i dont know what im talking about. dont listen to me.
Old Sep 11, 2006 | 09:25 AM
00JoeZ28's Avatar
it's a press-on. But has a hard time going on. And yes I've already put a micrometer to the snout and to the inside of the new hub. They are tolerenced correctly per chevy info.
Old Sep 11, 2006 | 09:35 AM
OBE1 95Z28's Avatar
You don't want to pull the hub in place with the bolt; you risk stripping the threads in the crank Purchase a threaded rod, thread the rod into the crank threads until it bottoms out. Use a washer and nut to drive the hub onto the crank snout. Lubricate the washer to reduce friction.
Old Sep 11, 2006 | 09:38 AM
00JoeZ28's Avatar
going to the depot to find materials. Thanks. Never really thought about that!! Will post in a few hours with what happened. Thanks for the info OBE1
David94TA's Avatar
What OBE1 95Z28 said. Get some all thread 7/16-20. Get grade 8 if possible.
Old Sep 11, 2006 | 10:16 AM
Javier97Z28's Avatar
Moderator
LT1's don't use keyed hubs from the factory.
Old Sep 11, 2006 | 10:19 AM
ya ya okay fine i lose. i read the post above.
Old Sep 11, 2006 | 10:23 AM
Loadre's Avatar
I prefer not to bottom out the threaded rod because sometimes there is enough friction between the nut and the rod that it will still try to spin the rod. Weld a nut on to the end of the rod to hold it or buy two extra nuts and tighten them down against each other on the end of the rod and you can hold onto that.
Old Sep 11, 2006 | 05:41 PM
00JoeZ28's Avatar
Thanks to all who put in the info needed. My new hub is now installed. Just need to do a few more things before I start it up and make sure it spins perfectly. But the ****ing thing is on now.
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
