Crankshaft Hub Install
Old Apr 14, 2006 | 07:22 PM
tritonium's Avatar
Trying to put the hub on the crankshaft - Where can we get a hub install tool to draw the hub onto the crankshaft or is there any other method to installing the hub that i am un aware of.
Old Apr 14, 2006 | 07:28 PM
boosted-lt1's Avatar
Re: Crankshaft Hub Install
Coat the crank snout with oil and use the hub bolt without the washer/spacer to get it started. That's it.
Old Apr 14, 2006 | 07:31 PM
tritonium's Avatar
thanks - im a bit weary to use that bolt ill get an extra bolt at the hardwar store tomorrow. thanks.
Old Apr 14, 2006 | 08:21 PM
BlackScreaminMachine's Avatar
I just did this a week ago, you need a threaded rod. 7/16" (20 threads per inch), which is a fine thread. The you need at least 1 bolt, and multiple washers so you can step it up to lay flat on the hub.
I also recommend chasing the threads with a die so they are ultra clean, once everything is on use a wrench and crank it on. Since you bottom out the rod, in the crank, the pressure is on the rod's thread, not the crank's
Most hardware stores do not have this.
Part Number: 92580A110
Found it on the website http://www.mcmaster.com/
Its a 3 foot peice but all you need is 10 or so inches, just cut it, chase it, sink it in and draw it on with hardend washers
Old Apr 15, 2006 | 02:16 AM
tritonium's Avatar
Thanks !!!!
Nov 18, 2023 07:21 PM
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
