Crankshaft
Old Oct 15, 2007 | 03:49 PM
97_camz28's Avatar
Crankshaft
will a forged 350 1 piece rear seal from a truck work in a LT1 without having to do anything extra?
Old Oct 15, 2007 | 03:51 PM
Quote from another website:
(http://www.automotiverebuilder.com/ar/ar99928.htm )
CRANKS
350 - The crank for the LT1 looks just like the one in the late 350 and has the same casting number 14088526, but it’s balanced for the lightweight pistons that were installed in the LT1. Be sure to keep these cranks separate so they don’t end up in a regular 350, and don’t ever use a regular 350 crank in a LT1. In fact, if you are short of LT1 cranks and don’t have a balancing machine in your shop, you would be better off using a crank from a 305 instead of a 350 because it’s actually closer to the balance specs for the LT1 crank.
Old Oct 15, 2007 | 03:59 PM
mdenz3's Avatar
If you match it with gen I SBC pistons will it work?
Old Oct 15, 2007 | 04:06 PM
97_camz28's Avatar
ive got a 350 1 piece forged crank GM powdered rods and speed pro hyp. pistons
Old Oct 15, 2007 | 11:35 PM
sam pace's Avatar
You are better off using a crank out of a 305.
The balance closer to the LT1.
Old Oct 16, 2007 | 12:21 PM
mdenz3's Avatar
I am really interested to hear if gen I pistons will work better with a gen I 1 piece rear main seal crank. I had already put gen I pistons in on accident and I currently am looking for a crank anyway.
Old Oct 16, 2007 | 12:49 PM
Z28SORR's Avatar
Originally Posted by shoebox
I hate this kind of advise! He tells you not to do something but doesn't fully explain.
I'm assuming that this only applies IF you are using the old style SBC crank with the stock LT1 pistons and rods, OR the old style pistons and rods on a stock LT1 crank.
AND that this does NOT apply if you are changing the entire assembly, (crank, rods, and pistons)???
Old Oct 16, 2007 | 03:42 PM
97_camz28's Avatar
my engine had gen 1 sbc pistons in it when i bought it with the stock GM powdered rods and stock LT1 crank, but im not worried about it now cause the auction on the crank on ebay is over so ill be using my stock crank
Old Oct 16, 2007 | 04:04 PM
It is pretty obvious he is referring to a rebuild situation that is like for like, which is exactly what the original poster was after.
Old Oct 16, 2007 | 05:52 PM
mdenz3's Avatar
But will a gen I crank work with gen I pistons in an lt1?
I have gen I pistons in mine because i didn't know beter when I ordered them, and now it has three spun mains I'm geussing from being out of balance. Seeing as i need to buy a new crank any way I was wondering if I ould get a gen I crank or do I need to get the lt1 crank and get some lt1 pistons.
Old Oct 16, 2007 | 06:54 PM
mdacton's Avatar
no matter what you use it still needs to be balanced.......will it run without it? Yes
Will it last?...hell no
Everything needs to be balanced....always in anything hi performance. stock would probly get by but rpms mean everything needs to be right
Old Oct 16, 2007 | 10:44 PM
jclark311's Avatar
I second the balancing, if you are not going to use stock lt1 pistons, and rods with a stock crank, and flywheel, you are going to have to get that rotating assembly balanced.
Slayer
Aug 17, 2015 03:55 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
