cranks but won't start
I just put in a new opti, maf is off, no coolant, no fans in yet. I figured i'd just start it once then put the rest in. The car won't start is it because the maf or coolant isnt in it?
Re: cranks but won't start
already double checked the pin, i had the maf plug connected one of the times i tried, just not the tubing connected, checked the coil. i have an ecu log i don't know if that would help, it wasn't giving me any codes. any other ideas?
checked all those today, and i still cant get to the bottom of this. I'm getting so pissed because i havent had this started in 5 months. any around mass. want to come down to help me out? thanks for your help thus far.
Pull your number 1 plug out and leave the wire on it. Set it close to but not touching a ground source and have someone turn it over. See if you getting spark. Does your fuel pump prime when you turn the key on?
This is off the wall, but a few weeks ago I had my car up in the air looking for a coolant leak and tried to start it to see if I could see it easier and the damn thing wouldn't start. Long story short- replacing the fuel filter fixed it. No starting problems up until then so there was no warning- just up and quit. Worth a $5 filter to eliminate it.
