it cranks but shuts right back off
Old Dec 8, 2006 | 07:47 PM
lt1BLAZER's Avatar
I have a 94 lt1 motor ina 87 s-10 blazer with painless wireing harness
and lt4 hotcam kit and the pcm has been reprogramed. It will crank and run for a few seaconds and shut back down, ive checked fuel,spark,etc. i cant figure it out someone help please!
Old Dec 8, 2006 | 08:06 PM
Dave89IROC's Avatar
classic VATS issue, make sure it was tuned out
if that is not it, its a fuel issue(pump not running with the key in the "on" position?)
I have a 94 LT1 in a 90 full size blazer
Old Dec 8, 2006 | 08:14 PM
mdacton's Avatar
is there a way he can disable this without sending the computer out again?
Old Dec 8, 2006 | 08:53 PM
Either programming or a bypass module (not the resistor bypass) like those sold on Ebay.
Old Dec 13, 2006 | 08:03 PM
lt1BLAZER's Avatar
the vats was turned off and the pump comes on when the key is on, before i put the lt4 hot cam kit in it it ran fine.
Old Dec 13, 2006 | 09:20 PM
taylorcrzy's Avatar
Check your optispark. Things are garbage, just went through my second one.
Chevyguy358
Jan 28, 2015 08:04 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 23, 2015 01:13 PM
1LEThumper
Jul 14, 2003 12:45 PM
