Cranking compression questions
Old Mar 7, 2004 | 07:40 PM
davepl's Avatar
Does anyone know what the normal cranking compression on an LT1 is?
My 396 with 9.0:1 is turning out about 155psi, I'm just curious how that compares to the 10.5:1 stock motors. I have a 236/236 cam which may be bleeding off a lot of cranking compression, even though its on 114 centers.
Also, how much variance is "ok" on a motor? If I have 157 on one and 152 on another, should I be upset?
Thanks,
Dave
Old Mar 8, 2004 | 12:56 PM
R_Andersen's Avatar
Well, for comparison, my 383 with 11.3:1 compression with the high lift 230/236 cam had 200-205 psi cold cranking compression when it was new.... 10% variance is usually acceptable but a fresh motor should probably have less variation than that..
-Rob
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
