Crankcase pressure....
Re: Crankcase pressure....
Originally Posted by Hawk350
oil catch? what is that? Where do I get one?
http://www.prostreetonline.com/buy/g...il_catch_cans/
I did the test where you remove the oil fill plug and put your hand over the hole to see if there is air coming out.....well, there was no air pushing out, it was like normal....what about the throttle body gasket that is under neather the tb? That holds the tb together? Could that be an issue?
Have ya done a cylinder leak test???? That's the test to do,your hand won't tell ya anything.
Do The TEST.
What happens when I have an airfoil installed on the throttle body. It blocks the pcv inlet part on the inside of the throttle body but not on the bottom part that controls the idle...should I take off the airfoil and modify it so it has a hole on the top?
RX Speed Works
Jul 24, 2015 02:25 PM
