Crank reluctor wheel / OBDI conversion question
Old Nov 10, 2005 | 01:39 PM
  #16
Colin91Z's Avatar
Re: Crank reluctor wheel / OBDI conversion question
Ok, I will see if I can figure out if my ASP balancer is sfi certified and get back yo you...
Old Nov 10, 2005 | 02:08 PM
  #17
Colin91Z's Avatar
Ok I called ASP, told them what part # I had and he told me that those were not SFI certified until about 2 years ago, and if mine was then it would be stamped into the front of it. Well, mine is not stamped, and I bought it over five years ago sorry.
Old Nov 10, 2005 | 02:28 PM
  #18
will62085's Avatar
hmm...well you wanna trade everything but ballancers then?...i might have an old 95 hub...i just threw one out, but ive got two
Old Nov 10, 2005 | 02:36 PM
  #19
Colin91Z's Avatar
Yeah, I would definatly trade hubs and timing covers, oh yeah and the reluctor wheel too. Is the 4 tooth gonna work for your needs?
  #20
will62085's Avatar
sorry...the hub i have is trash, it spun on the crank snout...but ill trade covers, yes the 4 tooth relucter is exactly what i need...if we trade covers and you include a good sensor and reluctor ill do what i can to re-imburse you for a good used 95 hub
Old Nov 10, 2005 | 02:56 PM
  #21
Colin91Z's Avatar
I would go for that. But just FYI, a new hub is around $50, and a new crank sensor is around $20. I'm sure mine is good because it everything worked when I converted it, but if you want to do this deal, I will include a brand new acdelco sensor.
Old Nov 10, 2005 | 02:57 PM
  #22
will62085's Avatar
you have a pm
Old Nov 10, 2005 | 05:47 PM
  #23
Lonnie Pavtis's Avatar
Reassembly with the stock '96 up hub & no reluctor will cause a misalignment of your serpentine belt. You may get away with this, but I do not recommend it. It can either wear the belt or may jump a few ribs under hard acceleration.
do it correctly & save yourself some headaches.
HectorM52
Jul 30, 2017 11:46 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Queens94z28
Dec 20, 2014 09:11 PM
redzed
Sep 4, 2002 06:22 PM
