Crank position sensor & OBD1
Old Jan 4, 2006 | 02:39 PM
walt355's Avatar
Im doing a OBD1 swap in my 96. Will I need the Crank positoin sensor? If not Im going to mend the hole in the timing cover while I have it off. thanks
Old Jan 4, 2006 | 02:51 PM
OBE1 95Z28's Avatar
Re: Crank position sensor & OBD1
OBD1 does not use the crankshaft position sensor. You can leave the sensor in place to plug up the hole, the PCM just doesn't talk to it. If you choose to remove the sensor and plug the hole, you need to leave the reluctor gear in place on the crankshaft as it acts as a spacer for the crankshaft hub.
Old Jan 4, 2006 | 03:37 PM
Colin91Z's Avatar
I did the same with my 96, and I ended up using a timing cover and crank hub from a 95 so I could eliminate the reluctor wheel too. Besure that you use a knock sensor from a 95 too
Old Jan 4, 2006 | 03:45 PM
walt355's Avatar
Thanks fellas. Ive already got the KS> I just wanted to make sure I would not need the CPS before I filled the hole with something. Mine leaks like a SOB or id just leave it in there THanks again
HectorM52
Jul 30, 2017 11:46 AM
VF-124
Mar 16, 2015 08:14 PM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
